Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Hole in Vinyl Liner - How to repair it?
    I have had a floating vinyl liner in the shallow end of my inground pool this whole season. It has gotten better lately but just today I found the source of the water under the liner. I have a 2" tear/hole in the liner that was hidden under a crease that had formed . I would like to patch it up myself but needed some advice on what to buy and how to do it, especially how to lay it down on a permanent crease in the liner.
    On a side note, is there anything that can be done for the creases that form in the liner? I likely need to replace the liner next year anyway but would like to try to smooth it out if possible.
    22000 gallon, vinyl, 1.5HP Century Centurion Pump
    Hayward Sand Filter (no.20 silica sand)
    PoolVac Plus Automatic Cleaner
    Oct 2007
    Cedar Hill, TN
    251
    I would like to know the answer, too. (We suspect a pinhole in our liner)
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Patching a liner isn't all that complicated - you need a piece of new liner large enough to cover the hole and some liner patch adhesive (Boxer 100 is probably the best) a pair of decent scissors and I like to use a wallpaper seam roller to help apply the patch. For patches on the floor I don SCUBA gear, a new patch needs to be worked for a few minutes to insure that it doesn't just peel right off. To properly apply a patch, cut a n piece of new liner material so that it is large enough to cover the tear with ~3/4" overlap and be sure to round off any corners unrounded patches come off fairly easily. Apply a thick, even coat of the adhesive to the back of the patch and fold it in half so that it's glue to glue. Unfold the patch right at the leak and apply it - this is where I use the seam roller roll the patch from the center out using good pressure on the patch then spend a minute or two rolling around the edge of the patch.
    This won't work if there is a crease where the patch needs to go - if you have water behind the liner you should be able to push the creases back to the walls. If you don't have water behind the liner, you can try using a toilet plunger to work out the wrinkles - as a last measure (if your liner has enough elasticity to be able to move the creases you can lower the water in the pool, work out the wrinkles and use a vac to hold the wrinkles out while the pool refills. - I wouldn't want to try this with an older liner or one that has been chemically abused - too much chance of ruining the liner)
    If you need a little more help with either patching a liner or removing wrinkles - simply ask
    Luv& Luk
    -Ted
    Rocklin, Ca
    467
    Although I live in an area of the country where vinyl pools are almost non existent, that's the kind of advice that really makes me glad you are back on board.
    Advice like that is why I chose to support this site.
    Thanks to all of our industry insiders.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Re: Hole in Vinyl Liner - How to repair it?
    ok before i try this...should i get some Boxer 100 or would the adhesive that came with the pool work as well? someone said i should try putting inside as well as outside. what do you guys think. i just want this to work out so bad!!! the pool is currently empty so we will be spreading the area out flat and try this...anybody care to come by and supervise??? well wish me luck and that i'm floating soon!! any more suggestions i'd be happy to have come my way. thanks so much for takin the time. good group here!! Linda
    ~David~
    Resilience SCC25 SWG, 14,585 gallons includes overflowing Jacuzzi, Rock Waterfall, Sand, IG, Pebble, Hayward Supra II 2 hp, Hayward S311SXV with 2" pipes (Sticker = GPM =99, user manual GPM = 80).
    Mar 2007
    4,160
    As I do mostly IG liner pools, it's often impossible to patch the underside of the liner. If you can get under the liner, by all means patch the backside too And put 2 patches if you need to on either side, put the first one on, as per above, and then cut another patch to be ~ 3/4" larger than the first and apply it after the glue has set on the first one, the more protection for the hole in the liner, the better it will stay sealed for the life of the liner 8)
    Welcome to TFP Zoodog!!!
    Luv& Luk
    -Ted
    thanks waste!! still not so patiently waiting for repair kit. almost ready to use the one that came with it but have it in my head that this boxer 100 will be best.
    ~David~
    Staten Island NY
    116
    As usual, thank god for this site! Didn't think this was a do it yourselfer but I know feel empowered to do so.
    Thanks to a wind storm last weekend, my gazebo decided to take a swim with me and the kids last weekend. Fortunately no one was hurt! I initially did not notice any damage to the pool until I notice the water level getting rather low. I initially chalked it up to evaporation (weather has been very hot) but today I noticed a tear/gap about 1-2 inches long at the seem where the floor meets the wall.
    I ordered the kit and am anxiously waiting for its arrival, however I already have one question. Is it better to use the patch that comes with the kit or an extra piece of liner my pool builder left for me?
    Thanks in advance and any additional advice you can provide.
    -400 sq ft ingroung Fiji (straight back kidney) ~ 13,500 gallons - Vinyl Liner - 3 to 6 Feet
    -Hayward 1.5 HP Super Pump
    -Hayward Perflex DE Filter EC65A
    -Hayward H 250 Heater
    22,393
    It's usually better to use a piece of the liner if you have it. It'll come closer to matching the existing liner than a patch probably would. If you're putting it on the back side of the liner it really doesn't matter though.
    Staten Island NY
    116
    Thanks Bama! Still waiting for the glue.
    Two follow questions:
    1-Am I doing harm waiting for this glue or should I run to the pool store to get it? Obviously the cost of water is starting to concern me.
    2-Does this explain why the liner appears to have a large bubble behind it, primarily above the water line? The bubble is in the shallow end which is also where the leak is? I'm assuming its not air but water?
    Mar 2007
    4,160
    Is the 'bubble' new since the leak or, was it there before? If there was always something behind the liner, it may have just worn through to cause the leak.
    There's also the chance that wall foam, if you have it, has floated in that area - gently feel the bubble and let us know if it's hard or soft.
    As a temporary patch, a lot of floating pool toys come with some self adhesive, thin patch material - which should at least ~plug the leak until you can do the job correctly
    Luv& Luk
    -Ted
    Staten Island NY
    116
    Thanks waste!
    I noticed the bubble before the leak but only shortly before (maybe a week). Perhaps I already had the leak and the gazebo made it worse.
    The bubble is very soft. Feels lik air. My thought is the water behind the liner is pushing up air to this area that is trapped. I also have no experience in this, therefore I maybe completely off base.
    Fortunately, my pool builder, added a PVC line that allows me to attach a shop vac, to pull back the liner. Once I properly repair, I'll try sucking out the water and/or air form this added PVC line.
    Mar 2007
    4,160
    Sounds good, however - the weight of the water would crush any air bubble behind the liner, hence my thought that it could be floated/ wrinkled wall foam.
    Please let us know how the patch holds, once you are able to apply it
    Luv& Luk
    -Ted
    Central Connecticut
    157
    Where is a good place on line to get a patch kit and boxer 100?
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Mar 2007
    4,160
    Any pool store should have them. I think Wallyworld and Ocean State carry them.
    Luv& Luk
    -Ted
    I have a hole about 2" long along a wrinkle in my inground pool. The wrinkle is longer than the hole and there are what looks like cracks on one side of the hole. I tried to repair with an underwater repair kit but it looks like there is water under the patch and the water level was low this morning. I have an extra piece of the liner left behind by the previous owners. Would it be better to try to cvoer the hole with a piece of the original liner? Can I cover over my failed patch?? Any help would be appreciated I regret buying a house with a pool.
    Mar 2007
    4,160
    Sher920, welcome to TFP!!
    (Go grab yourself a drink, I've got some bad news )
    It sounds to me like the liner is old or was chemically abused(the cracks give it away). Patching on a wrinkle is almost impossible (see my earlier post)
    You can certainly try applying 1 or more patches over the existing one, unfortunately - the larger the patch, the more chance it has of failing
    I am loath to say that I think you need a new liner, but it's my honest assessment.
    On the bright side, once you get this problem taken care of, you should not have any more problems with the pool (other than age induced equipment issues) - as long as you follow the methods we advocate here. This may not seem like such a silver lining, but it's a LOT better than what you'd get from following most pool store's advice.
    I'm sorry to have had to tell you this!
    Luv& Luk
    -Ted
    Thanks for your help!! That's what I was afraid of!!!! They told us the liner was only 3 or 4 years old when they sold us the house... but then we found out he used to dump bags of shock directly into the pool. The sand filter cracked and had to be replaced this week so with a new liner we're on our way to having an almost new pool. Guess I'll go have that drink now!!
    Staten Island NY
    116
    Sorry to hear the new posts but I just wanted to put some closure on my experience.
    As I waited for the patch kit, I decided to cut a small round patch out of some left over liner I had laying around. I then laid this patch over the hole to size it up and left it there. Believe it or not it stopped the leak! Without glue. I suppose the weight of the water? Whatever.!?
    Once I received the kit I glued the patch down following the instructions on the kit, i.e. use the glue sparingly. I waited one week with no issues. I then covered up this 1st patch with a slightly larger round patch and I appear to still be in good shape.
    I think I'm in the clear and wish the rest of you good luck! Thanks for the help eveyone!
  20. Back To Top    #20
    Mar 2007
    4,160
    Craig,
    You surmised correctly- the weight of the water ~ sealed the leak
    I'm glad to hear your issue is resolved! (I hope the others have as much success)
    Luv& Luk
    -Ted
