Results 1 to 7 of 7
Thread: Cloudiness
    Jun 2012
    Howard City, MI
    54
    Cloudiness
    Why is my pool so cloudy and yucky looking?
    I did notice it was looking a little yellowish on the bottom after I had left the cover off overnight......so I did a OCLT last night and it was fine. I am guessing it is just pollen and **** from the trees.
    My levels are currently:
    FC=4
    PH=7.7
    TA=150
    CYA=45
    *I added the appropriate bleach this morning as necessary to bring fc up and also bring ph down a little.
    Still, why would my water be so cloudy. I attached some pics that will hopefully show the cloudiness. Thank you for your help.
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Cloudiness
    If you added bleach to get to your current levels, that implies that the FC was lower before you added the bleach. If the FC was too low for too long, then algae can grow. You now report a 4 ppm FC, but what was the FC before you added bleach and what was the FC the last time you added bleach (before this time) and when was that?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Cloudiness
    Hotter weather, hotter water, more pool usage, not enough circulation, pollen--but most likely too low Fc numbers.
    Jun 2012
    Howard City, MI
    54
    Re: Cloudiness
    Quote Originally Posted by chem geek
    Sorry I wasn't very specific and didn't post all the info necessary.
    At end of day last night, my FC level was 4.5 (after very sunny warm day). This morning I checked it first thing and it was at 4. THEN, per the pool calculator, I added bleach to bring FC up to my target of 6.
    Jun 2012
    Howard City, MI
    54
    Re: Cloudiness
    So should i raise my FC to shock level?
    or since i only lost .5 overnight, assume the cloudiness issue is just from not covering pool overnight and pollen getting in?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Cloudiness
    Probably the latter. See if it clears up through filtration. If not, then you can shock, but given the low overnight loss it may be pollen, though that does create some (not too much) chlorine demand itself.
    Jun 2012
    Howard City, MI
    54
    Re: Cloudiness
    As always, thank you all for your help. Hoping for clear waters soon.....
