Thread: Vacuum recommendations
    May 2013
    Millbrae, CA
    41
    My Aquabot Breeze 4WD is doing an overall good job at keeping my floor floor and wall clean. I do break out my pole/whale brush XL combo now and then though to get spots the robot isn't getting to. That leads me to thinking that I should get a manual vacuum setup for the deep cleaning sessions I plan to do every few weeks or monthly, depending on need.
    I'm a sucker for improved technology so I'm asking here to see if anyone has suggestions for:
    - Traditional vacuum head and tubing. Any brands or special features I should look for/ cutting edge vacuum products? I'll probably grab a skimmer adapter also so I don't have to worry about junk messing up my piping or pump
    - Newer technology vacuum heads. I see some odd looking ones on Amazon. Any well reviewed ones I should look at?
    - Leaf blower. I like not having to worry about using pump/skimmer power and being able to just empty the bag when done. How are these with getting dirt though? I tend to get alot of sludge in my robot after cleanings so it looks like my pool needs something to help clean that out.
    Thanks!
    Pool: IG/Plaster/18k gallons/6 yrs old - Filter: Pentair Clean&Clear 320 Cartridge/120 GPM - Pump: Pentair Intelliflo Variable Speed/3hp - Cleaner: Aquabot 4wd Breeze
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Vacuum recommendations
    Good question...not sure. I need to actually buy a vacuum, so hopefully someone will stop by and help!
