Become a TFP Supporter Pool School
Results 1 to 14 of 14
Thread: New Pool (Intex UltraFrame 16x32)
    Upgrading from an Easy Set 18' that we had for a few years. Top ring had a slow leak, skimmer sucks, etc. I really wanted a rectangular pool, so I convinced my wife to get the big one. I had already upgraded the pump and filter last year so I'm reusing the filter and upgrading the pump. I am cutting out all Intex plumbing except the standalone SWG unit. All other components will be Hayward. Got 2 wide mouthed through wall skimmers and a handful of return fittings, all Hayward. currently in the process of plumbing but I wanted to start posting my pics and get some feedback.
    Re: New Pool (Intex UltraFrame 16x32)
    Site Prep
    Setting up pool. This thing is big
    Skimmers and initial plumbing
    You can see how the skimmers line up on the wall. I installed them on the side first, then cut out the middle. The gaskets that came with the skimmers that meet with the pool wall are U shaped, i think i saw someone call them butterfly gaskets. this wouldn't work for me, since I wanted to mount the skimmers and THEN cut the opening. So I sliced the gaskets in half and trimmed the excess material off with sharp scissors. I also got a pair of Intex magnetic LED lights. They work great!
    Close up of the skimmer on the side. I think Hayward shorted me a few screws, I had to swing by the pool place and grab a small pack. The Skimmer does lean a bit down, due to the angle of the wall sloping out at the bottom. Not sure how to correct this yet....
    I have the pool filled to the bottom of the skimmer bracket so far. More pics need to be taken. I have started on the return fitting plumbing. I plan on using both of the holes in the liner that Intex made for returns. I'm going to have 2" PVC running between the pump, filter and SWG, going to a tee, and reducing to 1-1/2" to the skimmers and returns.
    Jun 2013
    Southeastern British Columbia
    79
    Looking great. Thanks for sharing. We are about to embark on our 13 x24' x 52" ultra frame in a few weeks!!
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    Pool is filled, working on the plumbing. I'm using the original holes for returns and setting up 2 skimmers on either side of the pool. Ran out of pipe, had to go get more.
    They have a 13x24 pool?
    Jun 2013
    79
    Sorry it's 13 x 22. Exact same a intex butt made by polygroup. The pics look great, but oh my is it ever huge! I'm kinda freaking out
    Wow, looks great. Hopefully next year I'll set one up after backyard redo.
    Intex 16'x48"
    Intex sand filter, ozone SWG
    It is big but I wanted to get the largest I could at a decent price. That pretty much mandated Intex. Coming from an Easy Set pool, I'm fairly happy with their quality overall, but I will never buy an inflatable ring pool again, nor will I let anyone I know get one if there is a size in a frame pool that would work for them. I do wish that the sides didnt slope out so much, but theres a lot of water to hold in so I can understand why. We have a big yard so it doesn't make much of a dent in the amount of space used.
    Getting on with the plumbing. I have the return side finished, and opened up the valves so it is wet up through the SWG and to the filter. Working on the suction/skimmer side now. hopefully I'll have water flowing tomorrow.
