Thread: What is the benefit of automatic pool cleaner vs manual vac
    Hi all,
    This is my first summer of being a pool owner, so I'm still learning as I go.
    I found a Baracuda Alpha2 automatic cleaner left behind from previous owner. I'm curious as to how it's meant to be used. I know how to use it but am wondering, do I leave it hooked up all the time? I'm trying to figure out what's better. I have a manual vacuum head that I use a few times a week. I like using the manual because my pool usually has sand/dirt build up in the same few spots, so it's quick for me to go and vacuum those spots. I've watched the baracuda slowly and randomly go around pool floor. Am I correct that it'd take all day for it to clean the pool? So if I'm to leave it going all day, does that negativly affect the fact that no surface water is being skimmed? (Vacuum only works if I close main drain and 2nd skimmer line).
    Any feedback would be much appreciated.
    Thanks!
    27K gallon, IG vinyl pool, SD80 Sand Dollar sand filter-Michigan, 1hp pump
    22,542
    Re: What is the benefit of automatic pool cleaner vs manual
    You basically have it figured out. In order to get the pool as clean as you can with a manual vacuum, the auto unit would have to run a lot longer. It does affect the surface skimming when it's running, but since it's cleaning stuff up as it falls to the bottom it's not too bad of a tradeoff.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    I'm a new pool owner and I gotta say that I love my polaris. Stuff settles to the bottom and I put it in for 2-3 hours. After, it's all clean! I have not vacuumed yet.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Thanks for the input. I think I'll use it this weekend, and see how it goes.
