Thread: Newbie question about gallon per minute
    I have 15,000 Gallon chlorine water pool, it is equipped with Pentair IntelliFlo variable speed pump (new pool 1 year old), my deep end is 5.5 feet and my shallow is 3 feet.
    How can I calculate my Gallons per minute in different speeds ?
    Thanks in advance
    38,236
    Re: Newbie question about gallon per minute
    Welcome to TFP!!!
    Why do you think you need to know the GPM? It is actually not a trivial thing to try to estimate.
    FYI, the most efficient speed as far as $/GPM is around 1000 RPM.
    Perhaps this will help answer your question:
    pool-school/pump_run_time
    Thanks for the reply,
    the reason I want to know the GPM is to make sure I circulate the pool water on a daily basis, my pump is set to 1400RPM for 11 hours, I have 15,000 gallon, and if I knew how many Gallons per minute my pump circulates at that speed, I can calculate the daily gallons.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    The documentation for you pump should give you a approx idea
    Some pumps have g.p.m. On the data plate.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, pacman72
    Most pools do not need a full turnover per day (and a few need more). How long the pump needs to run is really controlled by your comfort with your pools clarity and other factors such as heating or method of chlorination, etc. Definitely take a look at the link jblizzle pointed you to above.
    Thank folks ! Appreciate your help !
