Results 1 to 11 of 11
Thread: Plugging floor returns
    Jun 2013
    Hunt Valley, MD
    62
    I had a leak between my pump and pump housing which I had my pool guy replace all the seals and gaskets. I also have a leak in the picture below marked with a red circle. When I spoke to the pool guy, he said since I have floor returns, they would have to get divers to go down there and plug the returns. I am new to pools and have not gone through a closing since we moved into this house back in March of this year. How do they plug the floor returns for closing a pool? Also, when replacing the leak area would you put valves right under the 90 degree piping to close it off in the future?
    Thanks
    -Dimitry
    28000 gallon outdoor in-ground Plaster Pool; 3/4 HP PB4-60 Polaris Pump; Magnetek Century Centurion 2 HP Filter Pump; Pentair FNS Plus 60sq ft DE Filter
    22,542
    Re: Plugging floor returns
    I got confused?? You started off talking about a leak and then it sounded as though the pool guy said they'd have to plug the floor returns in order to fix the leak, but then you wanted to know how they plug the returns for closing?? I'm really confused now!
    Jun 2013
    Hunt Valley, MD
    62
    Sorry about the confusion! I thought plugging the pool returns for a leak or closing it would be the same.
    Thanks
    -Dimitry
    38,251
    If the leak (pipe) is above the water level, then you do not need to plug anything for the repair.
    22,542
    Unless the equipment is below the pool there is no need to plug anything. The water will not rise up in the plumbing.
    As for as closing a lot of people don't plug them. They blow air into them and then air lock them with the valves. If they do plug them they have to dive down and install plugs.
    Jun 2013
    Hunt Valley, MD
    62
    The pool equipment is downhill from the pool so I assume if I cut the pipes, the water would start coming out. I am attaching pictures.
    Thanks
    -Dimitry
    22,542
    Since the equipment is below the pool you will have to stop the flow somehow. Looks like diving is your best bet.
    How many floor returns are there?
    May 2013
    NJ
    114
    How bad of a leak due you have at that point? You may want to try putting a stainless steel hose clamp on the fitting at that point. Sometimes it is enough to stop the leak until you feel like doing the long term fix.
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    Jun 2013
    Hunt Valley, MD
    62
    The pool has three floor returns and one drain. Pictures attached. Btw, how do you plug floor returns? Can you put some kind of suction bucket or cap on the floor returns to stop the flow temporarily?
    Thanks
    -Dimitry
    38,251
    Not to alarm you, but there is a frog on the bottom of your pool
    Jun 2013
    Hunt Valley, MD
    62
    I noticed that after I took the picture.
    Thanks
    -Dimitry
