Thread: Chlorine help
    Chlorine help
    Two nights ago at about 11:00pm there were about 9 slightly drunk teens enjoying the pool for about an hour. I expected the chlorine to be low the following mourning but it was only down 1ppm from what I was expecting. The following day with the cover on and no usage and 2ppm chlorine added the level was about 1ppm lower then normal. The question is how quickly does chlorine get used up after a pool party, is the demand still high for many hours after the high bather load?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Chlorine help
    Yes, it takes a bit of time for the FC level to drop from high bather load. I would expect that a couple of your "slightly drunk" teens peed in your pool.
    Suggestion -- bump your FC up a couple of points above your normal.
    22,543
    Re: Chlorine help
    It depends on what they introduced into the water. You could have an immediate chlorine demand that goes away immediately, or you could have something that takes a while for the chlorine to oxidize.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Chlorine help
    Be sure and check the skimmer for any lime slices. Don't ask me how I know this!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Chlorine help
    Quote Originally Posted by woodyp
    Well ok, I won't. But I sure want too.
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Chlorine help
    Lime slices -- FC loss -- hmmmmm.... sounds like something to do to to a pool store person's pool.....
    Just kidding!! I wouldn't be that mean....or would I?
