Thread: Plugging in Kreepy Krawler
    Jun 2012
    St Pete FL
    45
    Helping to take care of a friends pool. 20,000 Marcite sand filter. He recently bought the generic version of Kreepy Krawler. Shouldn't the hose be plugged in a port in the wall rather than where the vac hose fits inside the skimmer? There are three ports 2 or returns and the 3rd had a cap on it. When he took the cap off he said it was not a return port. So he plugged it into the hole the vac plugs into. Also can it stayed plugged in 24/7 and run on the same cycle the pump/filter runs on? Or should it only run a certain number of days and hours and let the filter run the opposite days and times????
    Thanks
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Plugging in Kreepy Krawler
    The Kreepy krawler is a suction side cleaner and should be plugged into the skimmer hole. No manufacturer recomends just leaving it in the pool constantly but a lot of folks do. It only works when the pump is on. I'd use it 2 to 3 times weekly and remove it.
    Jun 2012
    St Pete FL
    45
    Thanks woodyp
