Thread: I'm not sure about this BBB method
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    We left for Boston on July 1st and didn't get home until the evening of the 9th. 8 full days away from the pool with no one testing or adding anything. I did have a neighbor on stand-by to check the skimmer in case we had any storms or wind, but other than that, the pool was on its own.
    Came home to a sparkling pool with just a little dust and a few leaves in the deep end.
    I think I have it dialed in
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: I'm not sure about this BBB method
    Yeah...I'd say you've grasped the concept.
    Butterfly's Avatar
    South Carolina
    10,045
    You really have your pool trained Got a pic for us?
    You're done SLAMing when:
