Results 1 to 7 of 7
Thread: First time using TF-100
    Jun 2013
    San Antonio, TX
    7
    So here are my readings:
    Ph 7.8
    FC 1
    CC 0
    TC 1
    TA 140
    CH 330
    CYA 85 (down from 200+ we had some months ago)
    So I obviously need a lot of bleach. I'm still trying to find a good supplier for 12% bleach. It's just beginning of swimming season. Should I start by lowering the CYA by draining the pool or should I balance the other stuff first?
    I'm completely new to the bbb and still a little overwhelmed.
    Thanks for the help!
    10k gal, IG plaster+pebble, 4xcartridge 125sf, 2 ton waterfall, built Oct 2011
    38,408
    Re: First time using TF-100
    Definitely replace water to lower the CYA.
    What does the water look like? You will probably want to go through the SLAM process and that is easier with a lower CYA.
    Jun 2013
    San Antonio, TX
    7
    Oddly enough the water looks great. We had lowered the cya to 40ish but then were using tabs plus granular shock until I found this site. Just in a couple of months my cya has doubled. Still using tabs but trying to get off them as soon as I get me some bleach.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    The new concentrated bleach in stores is 8.25% which is pretty good. Just be sure to buy the unscented and plain Jane type. Not splash-less not outdoor etc.
    - Sent using Tapatalk
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Unless you find 12%, near your home, for a good price, I find the 10% to be the best value. I can get his at any box store for 6.47 to 6.86 for two gallons.
    YMMV
    -- Guy --
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by techguy
    YMMV
    Here in nc it is very difficult to find liquid chlorine except for bleach - I envy those of you with options. Even pool stores don't carry liquid in my area.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Most of the pool stores in my area do not carry 12%, so to get it , I need drive an extra 10 miles. No savings after I do that. So WalMart it is or HD.
    -- Guy --
