Thread: Compupool CPSC48 longer cell cord
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    About to install my CPSC48.
    I ordered the 15 foot cell cord with it, since the 6 footer is far too short for my install.
    The 15 foot cord came separate.
    I figured, no biggie, turn a few screws and attach the longer call cable.
    Welp, the cell cord is soldered to the system board.
    So, I need to break out the soldering iron to get this done.
    Not a huge deal, but I would have preferred it to be a screw/bolt on.
    Anyone else de-solder the 6 footer and solder in the longer 15 footer?
    Or did you just splice that bad boy?
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Compupool CPSC48 longer cell cord
    The site below recommends just using wire nuts. Does your controller look like that on the inside?
    How to Replace the Compupool Cable
    Unless you are pretty talented on soldering, I wouldn't take the chance.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    I don't recommend wire nuts. Cell cables handle high currents. Any imperfections in the connection will create a lot of heat, which will destroy the cable and whatever it is attached to after a while. I'd de-solder the old cable and the solder the new one in. But if you want, you can splice the cable, but you need to solder the splice.
