Thread: chemical question for new SWG
    lee872's Avatar
    Central Massachusetts
    59
    I am having a SWG installed, and want to get my chemicals where they need to be first. I'm going to get some liquid stabilizer and start bringing my CYA up on Friday. I also need to adjust both my TA and pH, and I'm not sure which to do first given the instructions on the sticky (pasted below).
    Quote from sticky:
    Adjust your Total Alkalinity to 60-80 ppm. (This is IMPORTANT!)
    Adjust your pH to 7.5-7.6 and not any lower. Monitor your pH and when it climbs to 7.8 add acid to lower it back to 7.5-7.6 (This is also IMPORTANT!)
    If I keep my pH where it is, my TA is too high, and if I lower my pH to bring my TA down, my pH will be too low. What should I do? I have about a week, maybe less, before installation.
    Today's test results:
    FC 6 (taken mid-day, it's usually 4 in evening)
    CC 0
    pH 7.5
    TA 120
    CYA 25
    CH 230
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: chemical question for new SWG
    If your PH stays there and doesn't jump around don't worry about TA. Or you could lower TA and raise PH with areation.
    Jeff
    lee872's Avatar
    59
    My pH has been real stable. Thanks!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    The addition of the SWG may cause you to start seeing ph rise, which you fix with muratic acid. This is do to the aeration that occurs in the SWG cell.
    Lowering TA is a process as mentioned above.
    Borates can help spread out PH rise with a SWG over time.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    I would suggest keeping the pH at 7.3 to 7.5 until the TA slowly comes down to about 60 ppm. Then keep the pH at about 7.6.
    Just check pH every day, or two, and add acid as needed to adjust the pH.
    Support the site
