Results 1 to 13 of 13
Thread: Pool pump
    Pool pump
    hayward or waterway?
    AG-Aqua Leader Jazz, 24'x52" Round, 14,633 gal, Hayward Power Flo LX 1.0 HP Pump, Clearwater II Cartridge filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool pump
    I have a Hayward 1hp 2 speed and like it alot.
    Jeff
    Re: Pool pump
    Thanks, I have one too but it needs to be replaced I liked it while it lasted
    38,305
    Re: Pool pump
    Just to add further confusion ... why not Pentair? Or Jandy?
    In reality they are all likely fine.
    Re: Pool pump
    Exactly why I'm posting, looking for some good input, thank you, I'll take a look.
    38,305
    Re: Pool pump
    Waterway is kind of a "lesser" brand (IMHO ... I could be wrong ) ... so they are likely a little cheaper. Although many members use them.
    I would certainly suggest sticking with a 1HP 2-speed at the largest.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool pump
    I agree.
    Jeff
    Re: Pool pump
    I like the idea of energy efficient but they are a bit expensive....(in the short term I suppose). And Hayward? Can get it delivered by Friday. Are there any other considerations I need to think of regarding the filter unit?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool pump
    Whatever you like. Bigger is better in the filter.
    Are you happy with what you have now ?
    Jeff
    38,305
    Re: Pool pump
    Are you looking to buy a pump or a filter or both?
    What size is you cartridge filter and we can tell you if the size is appropriate.
    Re: Pool pump
    Just the pump, the filter unit is a waterway, clearwater II Cartridge filter, Premium element filter CW2-11771
    May 2013
    Toronto, Canada
    73
    Re: Pool pump
    I noticed the Waterway 2-speed 1HP pump only draws 8.8amps@115v at the higher speed while 2.2amps at the lower speed. A similar 1HP Pentair Dynamo or Hayward draws around 11amps. Why the big difference?
    Philip
    Philip
    12.5x21.5x52" on-ground 29" below ground (6000 gallons water), .85 HP Hayward SP26115VSP , Hayward XStream 100 sq.ft. cartridge filter, Hayward AquaRite salt system, 160 sqft of Aquatherm solar panels on 12' high flat roof 25' away from pump, Goldline auto controller for solar, Heat Pump, May->October @77+ in Toronto, Pool Python.
    38,305
    Re: Pool pump
    All 1HP pumps are not created equal ... different wet ends will cause different power requirements ... and often they post inaccurate data online.
    But the 1/4 power draw on low vs high is normal. Low moves 1/2 the water. So even doubling the run time on low will give a 50% power use reduction.
