Results 1 to 13 of 13
Thread: Crystal clear water - stubborn stain/algae
    FC 1.5
    PH 7.5
    CYA 45
    Hardness 160
    Alk 90
    The deep end of my pool has greenish/grayish stains or algae that cannot be brushed away. I tried an algacide and daily brushing but still nothing.
    We've had over 17 inches of rain this spring/summer in the event that has anything to do with it.
    Should I shock my pool again?
    Thanks in advance.
    25,000 gallon in-ground pool, Nautilus DE filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Crystal clear water - stubborn stain/algae
    That FC is below the min. It shouldn't go below 3 for very long. What is your CC ?
    Jeff
    38,539
    You FC is clearly too low for your CYA: pool-school/chlorine_cya_chart_shock
    What is your CC?
    Is the water clear?
    What are you using to supply your chlorine?
    You may need to follow the SLAM Process due to the low FC.
    You can ID the type of stain by seeing if a trichlor puck will lighten it (organic) or if some crushed up vitamin C will lighten it (metal).
    CC - I need to get a better test kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Bingo !!!!
    Jeff
    What is your CC?
    Is the water clear?
    Water is perfectly clear.
    I use pucks in the skimmer basket and in-line chlorinator.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You do know what those pucks do don't you ?
    Jeff
    38,539
    I suggest further reading:
    ABCs of Water Chemistry
    Recommended Chemicals
    How to Chlorinate Your Pool
    I think the only reason your CYA has not gotten too high and resulted in a green pool is because you have gotten so much rain.
    You need one of the Recommended Test Kits and then you will be able to understand the water and determine if the SLAM Process is required.
    Quote Originally Posted by pwrstrk
    Sent from my iPhone using Tapatalk.
    Nope.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just what jblizzle wrote. Good advice.
    Jeff
    Just read about the pucks. Good times.
    While I wait for my new test kit to come in, should I SLAM my pool?
    38,539
    Pretty hard to do without the ability to test the CC or a FC > 5ppm.
    What did you use to get the results that you posted? You may be able to get a ballpark chlorine level with distilled water dilution until the kit arrives.
    Jun 2012
    Howell, NJ
    977
    It's going to be impossible to SLAM without the proper test kit.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
