Results 1 to 14 of 14
Thread: Pool is green
    Jun 2013
    Kansas
    29
    Pool is green
    Hello,
    Pool is a hazy green color.....
    PH..7.5
    Chlorine test shows almost a burnt orange color....almost ready for drain and refill.
    Please help
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Jun 2012
    Howell, NJ
    977
    Re: Pool is green
    You will need to follow SLAM (linked to in my signature as the shock process). To do this, you will need to know your CYA level. This will involve getting a good test kit, either the K-2006 or TF-100.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool is green
    +1 what John said.
    We need some good valid test results to help you. Read the SLAM PROCESS.
    Jeff
    Aug 2010
    Dallas, TX
    4,052
    Re: Pool is green
    Jun 2013
    Kansas
    29
    pool now just cloudy
    MOD edit: Let's keep your posts about this issue together. Thanks, linen
    Hi all,
    Pool is now just milky cloudy..no green.
    test results
    CL--burnt orange
    PH--7.5
    TA--250
    TH--300
    CYA--60
    Now what do I need to do?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Aug 2010
    Dallas, TX
    4,052
    Re: pool now just cloudy
    Did you just add the chlorine to bring it up to that high FC?
    Jun 2013
    Kansas
    29
    Posted this on July 10th (Hello,
    PH..7.5
    Please help).
    Used shock process, but have not added anything for 24 hours.
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Jun 2012
    Howell, NJ
    977
    Sounds like you need to SLAM the pool (formerly called shock process), which will be hard to do without the proper test kit. I believe those Intex filters can take a long time to clear up the water.
    John
    Jun 2013
    Kansas
    29
    Re: Pool is green
    I only have the hth 6 way test kit from walmart....so how can I move forward?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Pool is green
    Quote Originally Posted by Kim1965
    Well....
    For starters, what is the CYA level? If it's too high, the chlorine level to SLAM it will be outrageously high, which would make your situation pretty hopeless.
    If it's reasonable, there are work-arounds until you get the proper test kit, or at least the FAS-DPD portion.
    So let us know what the CYA level is.
    Here's another person who started out using your test kit. shock-not-working-t64500.html
    Jun 2013
    Kansas
    29
    Re: Pool is green
    CYA is 60
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Apr 2013
    Westside LA, CA
    49
    Re: Pool is green
    16x48 intex equals around 5000 gallons so adding 2 bleach jugs 8.25% should clear up your pool within 1-2 days.
    Keep the pump running.
    32x15 IG Borate+Salt, Pentair VS+SVRS, howard swim pure 40 SWG, Pentair 4000 48sqft DE, Mastertemp 300, Electric Pool Cover, Polaris P93, 4 Kids for Aeration, ;)
    30,426
    Re: Pool is green
    2 jugs of bleach probably won't be adequate. The SLAM process is about the only way to guarantee success. Follow it to the letter.
    Jun 2013
    Kansas
    29
    Re: Pool is green
    Hi, back again. Got the FAS/DPD test kit
    Results are:
    TA--210
    TH--250
    FC--34.5
    CC--0
    TC--34.5
    PH--7.2
    Pool is clear, but have what looks like sand lines on bottom of pool...at a complete loss of what to do next. Please help. I have pics of water but cannot get them to load to the forum.
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
