Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Need pool water help
    Hi everyone my name is jesse and new to the forums. Been reading alot of stuff on here and it seems that alot of people know what they are talking about so I thought I would post my problem.
    So on the 4th we had a bunch of kids swimming and the next day are pool was cloudy. That was on a friday so I waited to see if would clear up because it's happened before and it cleared up after a day. Never did so then I added did my weekely maintance. I add half a bag of Leslies fresh and clear oxidizing shock and half a bag of Leslies Genesis shock and add chlorine tablets.
    I would assume this isn't the ideal way to care for a pool but thats always worked so now I have this situation.
    So I went to Leslies to get my water tested and here are my readings:
    Free Available chlorine FAC 1-4 ppm condition low/ results 0
    Toatl Available Chlorine TAC 0.2 diffrence condition low/results 0
    Cyanuric Acid CYA 30-99ppm condition ok/results 40
    Total Alkalinity TA 80-120ppm condition ok/results 80
    pH 7.2-7.8 c9ndition low/results 7
    Base Demand Result 7
    Phosphates Belor Range 100ppb condition High/results 1000
    So they told me to put 2lbs of soda ash
    Add 1/2 bag chlorbrite
    Then add 36oz of PhosFree
    Well I had a friend with me and has had an above ground pool for 7 years and said dont buy it amd told me to put these chemicals in my pool:
    HTH Super concentrated clarifier and HTH algae gaurd 3x concentrate
    So I did and no results I also vacumed the bottom and cleaned the filters ect.
    I want to just drain the pool and fill it because it just seems easier and it will give me a chance to clean out the pool. We have 4 treed that have alot of pollin athat surrond the pool and we actually have 15 trees in are back yard so we are constantly getting leaves ect in it thats why I was wondering if I should just drain it and be done with it.
    Any help will be greatly appreciated.
    My pool is
    Intex
    16'x48"
    20k Gallons
    IG Outdoor Plaster
    DE filter (60 sqft I think, ID plate is worn)
    Haward RS 1500, 1.5 HP, 1.33 SF, 2.00 THP (cant find max flow rate and don't know what SF and THP are)
    Aug 2010
    Dallas, TX
    4,052
    Re: Need pool water help
    If that CYA of 40 is correct, you are EXTREMELY lucky. I'd like to see what you get on a CYA test if you test it yourself using a good turbidity style test (not strips).
    Ignore the phosphates and don't use phosfree unless you just have money to burn.
    A little soda ash is correct to raise your pH.
    Are you wanting to drain and refill, or just give up?
    I just want to drain and refill
    Why is the cya lucky. Sorry for the lame question I really don't what all the readings mean
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    Adding all those shock products typically will raise your CYA so high that you have no choice but to drain and refill. The pool stores will not tell you this, because they want to sell you those products.
    I would say given the numbers you have, you can go through the SLAM (shock level and maintain) process as defined here:
    pool-school/shocking_your_pool
    You are going to need a good test kit to go through the process.
    Problem is, I'm still concerned your CYA test number is not accurate, especially since you've added more product since the test.
    So would it be okay to just drain it give it a good clean and fill. This would all be done in one day so the pool wouldnt be sitting with no water.
    Also the pool water heats up lately to like bath water temp so I dont know if that's a problem
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    Yep, but keep in mind you will need to immediately bring up your chlorine (use bleach) and you'll need to get SOME stabilizer (CYA) in there again. I can possibly walk you through how to use the products you have on hand, but it can be complex to do so until you have a good handle on how each product affects your pool.
    I know it seems like the lazy way out but my kids are dying to swim and I just dont trust myself going thru steps of the slam thing. Iguess I over think things.
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    I helped a friend drain and fill a pool the size of yours for the same reason. When you are in that 5000-6000 gallon range, depending on how expensive water is in your area, it can be cheaper and easier.
    Well when I set up my pool earlier this summer I cleaned the pool while it was empty
    Filled it
    Added 1/2 bag fresh n clear and 1/2 bag of genesis shock and chlorine tablets
    Didnt ever have probloms until now
    But yes if you can guide me definently will take the help.
    Is it okay to buy products from walmart
    Also thank you for the quick response
    20k Gallons
    IG Outdoor Plaster
    The water guy here said it cost around $12 to fill the pool
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    It is OK to buy products from WalMart. Keep in mind though that for the most part, here we mostly only use PLAIN bleach (not "no-splash" or "outdoor"), stabilizer (CYA), muriatic acid if pH gets off, and maybe soda ash, borax, etc. if we need to adjust anything else.
    Fresh N Clear is Dichlor and will QUICKLY raise your CYA levels.
    Genesis is Trichlor and will also raise your CYA.
    The thing is, at first those products work because the CYA level starts at zero. But as you continue to add them, the CYA builds up and suddenly it's so high your chlorine is ineffective. This, and because pool stores typically get the CYA test wrong, is why I doubt the "40" number for CYA you were given.
    Also note they consider "99" to be OK. If you were at 99, you'd have a real issue.
    For $12, get to filling. Seriously. You'll spend more than that trying to get the pool back in balance, and again I'm betting your CYA is over 100.
    Aug 2010
    Dallas, TX
    4,052
    Oh, if you'll send me the weight of those packages, I can tell you how much to use in your new fill. You can calculate this at http://www.poolcalculator.com. Once you get them in though, you are going to need to switch to bleach or you'll be in trouble quickly again.
    Fres n clear 1lb
    Genesis shock net wt. 10oz
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    Each package of F&C will raise FC by 4, CYA by 4, and lower pH by .16.
    Each package of Genesis will raise FC by 4.3, CYA by 2.6, and lower pH by .23
    Both of them do basically the same thing, so you don't have to add one of each. You can use ONE of these each time you need to raise FC (hard for you to know without a way to test!) until they add up to a CYA of 30-40. Essentially 9 bags of whichever you choose, and no more. No matter what, no more. Not to "SHOCK" the pool (that's a pool store thing), not to continue to add chlorine. Once your CYA gets sky high, you are in trouble.
    Note I said one at a time. Adding two raises FC higher than you want it to be.
    So how should I start
    Empty
    Clean it
    Then start filling
    When is the proper time to start adding and I dont uderstand the whole bleach thing.
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    Please read here:
    pool-school/bbb_for_pools
    Add one package of either product when pool pump is running.
    So im gonna go to Wally World and buy a tester what else should I buy and what would you say I should put in the pool every week.
    20k Gallons
    IG Outdoor Plaster
    Aug 2010
    Dallas, TX
    4,052
    Once you can test your water, you can plug all the numbers into http://poolcalculator.com and it will tell you how much bleach to add (or for now use your products, but no more than 9 bags total!!!!)
    It's difficult to say how much chlorine you will consume, because there are too many variables. Swimmer load, sunshine, etc.
    30,420
    Please read "The ABC's of Pool Water Chemistry" up in Pool School....that'll help you get started understanding what we teach.
  20. Back To Top    #20
    So should I wait and get a tester before I drain the pool and I know there are a couple diffrent testers like a 3 way tester and 6 way tester and test strips which do you recommend
    20k Gallons
    IG Outdoor Plaster
