Thread: Advice on replacing 2hp pump motor
    Jun 2008
    Chicago, IL
    2
    I have an 18ft round AGP that is four years old. The salesman did me a "favor" by selling me the largest cartridge pump available at the pool store.
    I have a Hayward Swimpro CC1250 filter rated at a max flow of 90gpm.
    The pump is a Hayward Powerflow LX with a 2hp motor.
    The motor plate states it is an AO Smith motor part 7-193554-01.
    Frame: R48Y
    HP: 2.0
    SF: SFL
    Code: H
    115V 60hz 1ph 15 Amps
    I would like to go to a more appropriate size motor but can I use the same pump? Will I need to change out the impeller? According to the Hayward pump manual I am suppose to refer to the part number on the impeller.
    Any suggestions on a good source fo rthe motor?
    Rich
    Rich
    18' Round AGP with sparkling water
    Haywood Cartridge with a 2hp pump
    Lots of bleach
    Jun 2008
    Chicago, IL
    2
    Re: Advice on replacing 2hp pump motor
    I'm not sure if this is kosher here but I am bumping the post. Does anyone have any advice for me?
    Thanks in advance
    Rich
    Lots of bleach
    mas985's Avatar
    Pleasanton, CA
    11,737
    If you reduce the HP of the motor, you will also need to replace the impleller. Hayward usually lists the part number for the other implellers and motors so it shouldn't be too hard to replace both. Get the entire impeller kit which includes the seals as well.
    Here is a good place for the motors but there are so many places that carry them.
    Mark
