Results 1 to 17 of 17
Thread: sand filter problems
    May 2013
    s.w.Idaho
    9
    I have an above ground pool 15000 gal., 1.5 h.p. pump, 200# sand filter. when vacuming dead algea from pool it just passes through filter. I tried putting D.E. in filter, but it seemed to pass through also. I changed the sand earlier but still have problem
    15x30 above ground 15000 gal 200# sta-rite sand filter 1.5h.p sta-rite pump
    22,548
    Re: sand filter problems
    welcome to TFP.
    What is the filter pressure?
    Do you have a multiport or a slide valve?
    If you ave a multiport, is the valve set to filter and not to recirc?
    When was the last time you opened the filter?
    Is there any leaks around the filter?
    Is there any water leaking through the waste port?
    May 2013
    s.w.Idaho
    9
    welcome to TFP.
    pressure is 10# multi port valve set to filter,opend filter week ago,no leaks,don't know if leaks at port vale. how do I check?
    May 2013
    s.w.Idaho
    9
    pressure is 10#, multi port set to filter, opened & changed sand week ago, no leaks @ filter, don't no if leaks at port valve, no visable leaks on outside
    30,419
    Welcome to the forum.
    Did the filter do this prior to changing sand?
    22,548
    Are you getting sand in the pool?
    May 2013
    s.w.Idaho
    9
    yes thats why I changed the sand & checked the laterals.
    May 2013
    s.w.Idaho
    9
    no. no sand in pool; only looked like whI added D.E., it looked like it was coming out into pool
    22,548
    In all likelihood it's probably the multiport valve bypassing internally.
    Have you taken the top off the valve and inspected it?
    30,419
    Reinforcing bama's post, it sure sounds like your multiport has an internal problem allowing some of the unfiltered water to go back to the pool.
    May 2013
    s.w.Idaho
    9
    ok. so what do I do from here?
    30,419
    Disassemble the multiport and inspect it for any visible sign of a problem. Particularly, the spider gasket.
    May 2013
    s.w.Idaho
    9
    ok. if I have any questions I will get back on, thank you all.
    22,548
    It would be great if you'd put your pool and equipment info in you sig. That way we don't have to look for it in a post.
    Once you take the top off the multiport valve it will probably be obvious what the problem is if there is one.
    May 2013
    s.w.Idaho
    9
    sorry. I didn't have that info when I registered, and don't know how to enter it now. I would be glad to put it in my sig if you will tell me how. thank you all for the help.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Welcome
    Upper left, user control panel, profile, edit signature.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    May 2013
    s.w.Idaho
    9
    Quote Originally Posted by msgtdan
    Welcome
    ok. thankyou Dan.
