Thread: How long to run a pump for
    Hi from the UK new to the forum, Just wondering how long should I run my filter pump for we have just brought a 12ft bestway frame pool and its 30inch deep (would of liked bigger but kids are still small) it came with a filter pump Bestway Pool Filter Pump - Grey, 1249 Lt 1250 litres per hour / 330 gallons (US) per hour, or should I get a better one.
    Also when is the best time of day to test the water on the clear water test strip morning or night and also when to add the clearwater chlorine granules morning or night or other chemicals if needed. We have done the shock in the swimming pool and at the moment everything seam fine all the levels seam fine...
    New Orleans, LA
    22,539
    Re: How long to run a pump for
    Welcome to TFP.
    You run the pump long enough to keep the pool clear. With that small a pump and filter you're probably going to have to run it 6 or so hours a day.
    It really doesn't matter when you add the chlorine, but you should add it when the pump is running and is going to remain running for about an hour after the addition.
    38,235
    Welcome to TFP!!!
    Take a look in Pool School ... lots of good info.
    Here is an article about pump run time: pool-school/pump_run_time
    What do you mean "done the shock"? Did you follow what we call the SLAM Process to ensure that there is nothing in the water? Although, if this was a new fill, then there is no need to do that.
    I would also recommend reading these to get a good understanding of the chemistry:
    pool-school/pool_water_chemistry
    pool-school/recommended_pool_chemicals
    pool-school/types_chlorine_pool
    I brought a Clearwater starter kit and reading the pool guide it told me to add a shock/ starter dose which I did and reading on the test strip are fine .. Thank you going to have a read on the links you gave me.
    Thanks for the help
    Welcome to TFP!!!
    New Orleans, LA
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Welcome
    Test strips are notoriously inaccurate, a good test kit is a must. Not sure if Duraleigh can ship TF-100 to the UK but you should be able to get the Taylor K2006.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Thank you everyone
    New Orleans, LA
