Results 1 to 7 of 7
Thread: CC = 0, is that good or bad?
    I've tested my pool using the chlorine test in the TF-100. In all the times I've tested, my CC = 0. I can't seem to find a good answer as to whether this is good or bad? I think it's good, but would like to make sure.
    --Michael
    33,000 Gallon, 20x40 Vinyl Inground, 500sq feet cartridge filter, 3/4 HP Hayward Super Pump, Installed 6/2013. Central Virginia, USA
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: CC = 0, is that good or bad?
    That is a good thing.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Excellent! Above .5 is bad. It's one of the indicators used to SLAM (Shock Level And Maintain) your pool.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Great, thanks. So as long as this stays 0, no need to shock the pool (assuming FC is where I want it)
    I would add to the responses above - ".... as long as the FC is above the minimum for your CYA."
    0 CC with correct FC is good
    0 CC with 0 FC is bad
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    It's a complex chemical process but simply put....CC is created anytime organic substances are oxidized by the chlorine in your pool (which is anytime someone gets in the pool). The catch is there needs to be enough additional FC to break down the CC and complete the process. If you are detecting 0 and you are maintaining the right FC....everything is happy.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    0 cc is only one of the indicators, if the water looks dull or cloudy, if you see visible algae, if you can't hold chlorine overnight then you might need to SLAM your pool. If everything looks good and you're holding chlorine overnight then your fine.
    Dan D
