Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Converting from Baquacil to chlorine
    Having trouble I think with my conversion I started yesterday. I do not have the recommend test kit as I can not afford it right now. I've spent over $600 at the pool store this summer alone! [attachment=0:1zhtlatz]ImageUploadedByTapatalk1373467891.453942.jpg[/attachment:1zhtlatz]
    Help!!
    24 ft AG Round Pool. Converting to Chlorine!
    38,540
    Re: Converting from Baquacil to chlorine
    Welcome to TFP!!!
    Why do you think you are having trouble? Have you read the countless conversion threads here to see what to expect?
    You are certainly going to struggle and waste some money by not having one of the recommended test kits. What is < $100 for the required tool that will save you money when you have already thrown $600 down the drain.
    I have been following the TFP method for conversion. But working days and adding bleach often had become an issue. There is still a lot of Baquacil oxidizer in it.
    38,540
    Well, if you are following the conversion method, you know that the answer is more chlorine ... there is no shortcut, well besides draining and starting over which would still require following the conversion process.
    Do I also add shock and algaecide as I go? What is stabilizer? Can I purchase at Wal Mart?
    Drained below skimmer yesterday. Washed the basket in the pump. It was completely covered in green slim and hair...etc...
    I flocked twice already. Vacuumed to waste. Brushed. Vacuumed to waste again. Added more fresh water.
    Added bleach again this morning after I Backwashed and rinsed.
    How many days does a conversion typically take?
    Can I buy a test kit locally or is online the only way?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Not a baqugoo expert but my understanding is you need the TF100XL and lots and lots of bleach. I know the cost of the kits can be daunting but it will save you lots of time, effort and money during the conversion and this summer. I say the XL as you will be testing f or chlorine in the 10-30 PPM range several times per day. The other test kits stop at 5 PPM and you need to accurately measure up to 30 PPM.
    The bleach you need for this process can be 10 to 50 gallons of bleach. How much will depend on how often you add chlorine and how much goo you find in your pool. More frequent additions appear to make it go faster and use less chlorine. The CL is used to consume the goo you have now.
    -- Guy --
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I bought my TF100 locally in Rocklin,ca but unless you are near Raleigh, NC or Rocklin, Ca, online will be easier.
    -- Guy --
    I've already added 3 gallons. Should I also use the chlorine tablets?
    Just placed order for tf100xl test kit.
    Smykowski's Avatar
    Sep 2011
    3,065
    Reread the Conversion article in pool school, and take a look at some of the conversion threads. They will give you a good idea of what to expect.
    I've read it so much I have it memorized! I've also read many threads on here...
    I'll have to wait...
    38,540
    Quote Originally Posted by MJReno8
    And yet you are asking a lot of questions that are not part of the process ... like algaecides and pucks and talking about using flocks.
    You just need a lot of liquid chlorine at this point and a way to consistently keep the FC around 15ppm ... the kit you ordered will certainly help. What kind of testing ability do you currently have?
    What step in the conversion process do you think you are on?
    Later you will need to add stabilizer which is cyanuric acid and yes it can be found at Walmart.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    For a BGoo to CL conversion, at the beginning, all you will really need is a truck load (20 bottles? to start) of chlorine. If your PH was good to begin, you can't measure it until the next time your CL is below 10 so keep filtering and keep your FC up to the recommended levels, every hour at the start.
    You need the TF kit to be able to measure your FC as it will be in the 10-30 PPM range for the foreseeable future and the "store" test kits can't measure this range accurately (I see you ordered--good job!)
    Really, nothing else matters until you get back to a clear pool and your FC holds overnight.
    -- Guy --
    Ok thanks. It is looking better.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Keep adding CL, keep pumping.
    If you want to do something productive, brush your walls, brush your floors. Take out your ladder and wash it.
    What is that hanging into the pool off the back wall? Take it out and wash it, too.
    -- Guy --
    A light.
  20. Back To Top    #20
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would assume (dangerous, i know) that you should take out the lamp, take it apart as much as you can, and wash it out. I could be full of the B-goo and it will take longer to clean it in the water than if you took it apart and did it manually. it is amazing the stories i read about where this stuff hides in a pool.
    I have read these stories for years and I am always impressed by the results of an aggressive conversion. Those that let the pool take it's time struggle much longer than those that attack it with a vengeance.
    -- Guy --
