Thread: VS Pump keeps tripping GFCI Breaker
    I've done some searching and while I have read a lot of posts from people who have had GFCI/Pump issues, none seem to be identical to what I am experiencing. I'm hoping others can shed some light as to what might be making my breaker trip.
    I have a Pentair EasyTouch 8 Panel with a StaRite VS-3050 pump. The pump is currently wired directly to a 20A 240V GFCI breaker in the panel. The breaker is NOT connected to anything else - it only serves the Pump. The panel and the pump are both located outdoors and are ~1.5 years old.
    Periodically, I noticed this breaker tripping last pool season --- this occurred about once every week or two (sometimes more often, sometimes less). When I would flip the breaker back on, everything would work fine again for another 1-2+ weeks. When this same behavior continued into this pool season, I called Pentair as I thouht the pump might be the culprit. They sent a tech out to my home who identified that the Electrician had originally wired the pump breaker to a relay which was also powering the IntelliChlor transformer --- he told me that this was incorrect (which I have since read a lot about on this site) and that the pump breaker should not be connected to anything by the pump itself --- not a relay.
    About a 1.5 weeks ago, I re-wired my panel so that the pump is now directly connected to the 20A 240V GFCI breaker - it is no longer connected to a relay. I was optimistic that this re-wiring would solve my tripping issue --- however, the breaker has tripped twice since I completed this work.
    I have considered ordering a new 20A 240V GFCI breaker for ~$100, but before I drop the cash, I'd like to have a better sense whether or not this is the actual problem. Unfortunately, I am not sure how to determine if the breaker itself is the issue, or if our issue is pump/wiring related. Is there anyway for me to identify what the source cause of this is using a multi-meter? Is there anything I should be looking for at the pump that could cause the breaker to trip?
    Thanks!
    41' x 16' x 7' deep rectangular IG FG Blue Hawaiian Olympic Bay model w/ Glacier Blue 'Extreme Quartz' finish / 2 skimmers, 4 returns + 1 dedicated vacuum line / Sta-Rite IntelliPro VS-3050 pump / Sta-Rite System3 Modular Media S7M400 Filter / Pentair EasyTouch w/ ScreenLogic 2 / Pentair IC40 SWG / Pentair UltraTemp 120 Heat Pump / Coverstar Auto-cover / Savi Color Changing LED Pool lights x 4 / Pentair MacgicStream Laminar LED Deck Jets x 4 / 2 x 2 Jacuzzi Jets installed on shallow and deep end steps / SR Smith Typhoon Waterslide / Polaris 9400 Robot. See my build thread HERE
    Re: VS Pump keeps tripping GFCI Breaker
    It is quite likely that it is the breaker, but there are other possibilities. I can't think of any easy way to narrow it down short of trying a new breaker.
    Aug 2011
    Southern California
    188
    I recently bought a boatload of breakers, both GFCI and regular, for my new Easy Touch/Intellifo VF setup and found Global Industries had excellent prices. Might want to check the price of what you need there.
    Wired mine directly to the breaker.
