Thread: Trying to increase my CYA
    Feb 2012
    San Jose, CA
    76
    The essentials:
    FC 3
    CC 0
    CYA 5-10
    pH 7.8 (just added a gallon of 14.5% muriatic acid, which should lower this considerably)
    TA 230
    CH 160
    I've added about 90% of a 4 lb tin of CYA powder, and my CYA barely moved even after about 2 weeks! I put it in the skimmer, but didn't use a sock. There are two holes underneath the skimmer basket plate - to vacuum, our PB said to cover the left one with a tennis ball and hook a vacuum hose up to the right hole. Could it be that the CYA powder went down the wrong hole, and is just hanging out down there (or worse, clogging something up)?
    Edit: I just realized that 1 lb is 16 oz, not 32 oz. Whoops! Looks like things are ok then, if my CYA level is at 10 after 50 oz of CYA powder. Could someone still explain what the two holes underneath the skimmer are for? Thanks!
    Filled 5/1/2013! 36k gallon 20x40 IG with 7x7 spa, FinestFinish, AquaMatic cover, All Pentair: Clean&Clear 520 sqft cartridge filter, Intelliflow 4x160 variable speed pump, 2 HP whisper flow spa jet pump, 400k BTU MasterTemp heater, Letro Platinum pool cleaner, Rainbow 320 chlorine feeder, Pac Fab Bermuda skimmer
    More details: pics-new-pb-20x40-ig-gunite-7x7-spa-7x7-shamu-shelf-t54952.html
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Trying to increase my CYA
    Have you back washed the filter since you added the CYA?
    -- Guy --
    Feb 2012
    San Jose, CA
    76
    Nope.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The other hole is probably connected to your main drain but normally that's already plugged.
