Thread: Is this Calcium Scaling?
    Feb 2012
    San Jose, CA
    76
    First off, the important stuff:
    FC 3
    CC 0
    CYA 5-10 (trying to raise this)
    pH 7.8 (just added a gallon of 14.5% muriatic acid, which should lower this considerably)
    TA 230
    CH 160
    Now, I've noticed this around my water line - is it calcium scaling? Is this a reason to lower my TA (aside from wanting to go to borates)?
    Filled 5/1/2013! 36k gallon 20x40 IG with 7x7 spa, FinestFinish, AquaMatic cover, All Pentair: Clean&Clear 520 sqft cartridge filter, Intelliflow 4x160 variable speed pump, 2 HP whisper flow spa jet pump, 400k BTU MasterTemp heater, Letro Platinum pool cleaner, Rainbow 320 chlorine feeder, Pac Fab Bermuda skimmer
    More details: pics-new-pb-20x40-ig-gunite-7x7-spa-7x7-shamu-shelf-t54952.html
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Is this Calcium Scaling?
    It's hard to tell from the pic, but the classic signs of a calcium ring are not jumping out at me. When I moved in to our current house, the pool had a much more prominent calcium ring (which has since disappeared since going BBB). Your CH number is actually a bit low for a plaster pool for which the ideal range is between 250-350 ppm. Your pH and TA are on the high side, as you have noticed. Focus primarily on lowering pH to the lower half (e.g., 7.2 - 7.5) of the recommended range. Periodic additions of Muriatic Acid to keep pH in check will also lower TA.
    BTW, keep raising CYA - you want a minimum of 30 ppm.
    Feb 2012
    San Jose, CA
    76
    So it's probably just grime? I brushed it, and it didn't budge. How can I safely clean it, without causing soap bubbles in my water?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    A pumice stone and elbow grease is how you clean that. It will sound awful - like fingernails on a chalkboard - but it works and you won't see scratches. You will see a lot of pumice grit on the bottom of the pool that you'll need to vacuum up. And it takes a huge toll on shoulders, so predose yourself with some motrin.
    Feb 2012
    San Jose, CA
    76
    Lol sounds good, thanks for the suggestions!
