Thread: Center drain for above ground pool
    Are center drains still recommended for above ground pools? I read a few sites that said center drains are being replaced with automatic cleaners. I'm looking to install a 15x30 oval pool.
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Center drain for above ground pool
    Welcome to tfp, tricitydeals
    What climate do you live in? If you live in a northern climate that freezes I would not do a center drain. Not worth the risk of freezing or the work to prevent it imo.
    Thanks for quick response. I'm from upstate ny. I assume I should stick with a automatic cleaner?
    Where can I find post on leveling the ground for for oval pool? I can't seem to find any search features.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Use the google search up near the top right of each page.
    As for the bottom drain in your climate...I would skip it.
