Thread: Disconnecting Copper?
    grisetti's Avatar
    Jul 2013
    Ferrum, Virginia
    8
    Please excuse my ignorance and if this is posted already somewhere, please redirect me.
    I have seen a few posts about disconnecting the copper plates in the SWCG.
    What is the deal with disconnecting the copper connections in the SWCG?
    Why would you do that? How is it beneficial?
    Does it effect the performance of the SWCG?
    Lastly, How is it done, if it is beneficial? (any pics - I am a visual learner )
    Thanks for your direction.
    Joe "Newbie"
    Intex 16'x48" Round UltraFrame, 2500 g/per hr pump upgrade, Krystal Clear SWCG, Hayward above ground Propane Pool Heater, Intex Skimmer, Intex magnetic pool light, FlexHead weighted vacuum with Intex adapter to connect to pump intake.
    Sep 2009
    Greentown, IN
    914
    Re: Disconnecting Copper?
    When copper and chlorine meet the copper oxidizes and makes blond hair turn green...
    Here is a post that describes how to remove them. http://www.troublefreepool.com/how-t...wg-t57921.html
    Mine is an older unit that does not have the bars, so I can't personally walk you through it.
    Some think it's fine to just unplug them, others say remove. I think I would lean toward removal myself.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Sep 2009
    Greentown, IN
    914
    Oh.. copper is used because it is a natural algaecide... used in many algae prevention products.
    Test kits compared
    Purchase test kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    A Suziqzer said, although copper is an algaecide, it also stains pool surfaces and can turn blond hair green. In addition, if you keep your FC (free chlorine) at an appropriate level, you do not need the copper (or any algaecide).
    To disconnect bars just unscrew the retaining nut and pull off the connector...you can just leave it hanging.
    It does not effect the performance of the swg.
    grisetti's Avatar
    Jul 2013
    Ferrum, Virginia
    8
    Thanks for the information!
