Thread: Help with targets?
    Jun 2013
    Charlotte, NC
    18
    Help with targets?
    Hey all. Posted a few days ago in another topic about getting my test kit and next steps...that convo came to a stand still, so I'm hoping to get some final help with my target levels to put into pool calculator when my FAS-DPD kit comes in and i'm ready to start the shock process. (green pool currently, sigh). I want to know which of the BBB chemicals to purchase and what to add to get all my chemistry in balance!
    So my levels the other day were (and I fully intend to retest once full kit is here)
    Currently at: (and I'm aware that we literally have no chlorine in the pool; we went away to NY for a week and came back knowing we'd start fresh, only have the dreaded tablets I've been told not to use, so we haven't added anything until we know for sure what to do for shocking process)
    FC: 0
    TC: 0
    pH: 7.4
    TA: 50
    CYA: 45
    CH: 110
    Based on my stats below, any help with what targets should be at? If CYA is 45, using the chart I found here on tfp I should be FC shock level of around 18 (between 16 and 20), correct? So I'm going to maintain at shock level until the three criteria are met (CC of .5 ppm, overnight loss test of 1.0 or less, clear pool)....anything else I have to do? I know my TA should also be higher, between 70-90+...so my real question is, with such a range, 70-90, what do I put in as my target for the pool calculator??
    Any help is sooooo appreciated!!
    Charlotte, NC
    16x32 pool, 3ft shallow end, 8 foot deep end
    Hayward Sand Filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Help with targets?
    I'd shoot for a TA of 70 to start with.
    Everything else looks good.
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Right now, all you need is plain, unscented liquid bleach without any thickeners...and lots of it. Job 1 is to get rid of the algae which involves SLAMing the pool (formerly called The Shock Process). As soon as your FAS-DPD kit arrives, you can begin this process. Once the pool is cleaned up, we can then focus on any water balancing adjustments that may be needed.
    Quote Originally Posted by weilerfamily0906
    Yes.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Just kill it.
    Everything else is easily fixed once the water's clear.
    Jun 2013
    Charlotte, NC
    18
    Yay thanks everyone!! Ordered the FAS-DPD today and I already have the DPD kit from Leslie's for the rest; once those both run out/next season I'm definitely getting the TF100. Once that's here I'm ready to SLAM (love the new name ) this swamp!!
    Charlotte, NC
    Hayward Sand Filter
