Thread: CYA question... Am I on the right track?
    Southern Indiana
    229
    Hi guys... question...
    I have a CYA at 30... I shoot for 4 PPM for chlorine per the Pool Calculator and trouble free pool methods. Here is what I am seeing...
    over night loss test is 1 or less
    If I bring Chlorine up to 6 PPM at night approximately 24 hours later I am at 2 PPM (which is the minimum for my CYA).
    Should I bring up the CYA so that I am closer to the 4 PPM which is the recommended amount... Or would you say that after a hot day of full on sun that this is about right?
    Thanks guys...
    Also FYI
    PH - 7.5
    TA about 70
    Water sparkles, I just need some reassurance I am doing the right thing...
    Pool 16 x 33.5 Foxx Pool with rounded corners 3.5 at each end and 5+ in the middle (16000 GAL)
    Equipment - 300 LB Hayward filter with a Pentair SuperFlo pump (3/4 HP). Also Hayward H series Heater and a dedicated jet for a Polaris 280 with a booster pump (3/4HP). Hayward Chlorinator CL200.
    Pool has Main Drain, 2 return Jets with 1 inch eyeballs, a skimmer with floating weir, and the dedicated Polaris jet. Also has a valve for the Waterslide.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: CYA question... Am I on the right track?
    Yes the hot weather, sun, water temp all contribute to FC loss. Try going up to 40 ppm on the CYA.
    What is your CC ?
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    That sounds normal, but higher FC loss than I'd be happy with. I'd take CYA up to 40 or 45. Leave yourself a little breathing room so you can use pucks in a floater if you leave town for a vacation.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    You could very well need to raise your CYA level to avoid so much of a daily loss. Your minimum and target levels also go up if you do. Anything over 3 to 4 loss is excessive without a heavy swimmer load.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Be sure to check and clean the skimmer baskets and pump strainer baskets. These can harbor trapped debris that may not be visible in the pool but will still increase your chlorine consumption. I run a CYA in the 30's, which is on the low side given the Texas summer sun and a pool that gets direct sunlight for much of the day. However, I am militant about keeping these items clean. The most FC I have lost in a 24 hr. period so far this summer is 2.5 ppm. The more common daily mid-summer FC loss for me on a sunny day is around 2 ppm.
    Southern Indiana
    229
    Thnx guys... I will clean the baskits and check it agn. If needed I will bump CYA 5 at a time and retest. More to follow.
