Results 1 to 10 of 10
Thread: Water Balancing
    Oct 2011
    Chicago, IL
    113
    Water Balancing
    Hello all, i noticed on Wednesday of last week that I was beginning to get algae forming on the sides and bottom of my pool. I shocked it with bleach and then added algaecide. I noticed that it is coming back in certain places but not as prevalent. I am new to owning a pool, so I am not sure if this is common. I live in a heavily wooded area and leaves constantly fall in and I do my best to keep it clean. I did a water test today and here are my readings
    TC - 8
    TA - 90
    CA - 160-180
    CYA -30
    PH - 7.5-7.8
    THoughts?
    I have a 35,000 gallon, sand filter, sunken above ground (so inground), vinyl liner, with an Aqua rite turbo cell SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Water Balancing
    Shock is not a one-time mega-dose. It is a sustained process that can take several days, possibly weeks. All you've done now is beat back the algae. It will reproduce, regroup, and stage a counterattack unless you keep after it until it's all dead. pool-school/shocking_your_pool explains it in detail.
    Jun 2013
    SpringHill FL
    415
    Re: Water Balancing
    You have no fc or cc listed what test kit are you using?
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Oct 2011
    Chicago, IL
    113
    Re: Water Balancing
    fc - 8
    cc - 0
    I am using the tf-100 test kit
    Jun 2013
    SpringHill FL
    415
    Re: Water Balancing
    Have you brushed the walls and floor? Are there slimy spots on the vinyl?
    Nathan
    38,305
    Re: Water Balancing
    Come on Richard ... the shock process is so ... 1 day ago.
    Is it now the SLAM process. [slam:1e8lqgrr][/slam:1e8lqgrr]
    Richard320's Avatar
    Jan 2010
    19,023
    Re: Water Balancing
    Is it now the SLAM process. [slam:6190gtl8][/slam:6190gtl8]
    I just pasted the URL straight off the address bar, and that's what came up. Blame the webmaster for not creating a new page and then setting up a redirect to it from the older URL.
    38,305
    Re: Water Balancing
    Quote Originally Posted by Richard320
    Is it now the SLAM process. [slam:14r5gahb][/slam:14r5gahb]
    Yeah, I know I brought that issue up with them.
    Oct 2011
    Chicago, IL
    113
    Re: Water Balancing
    looks like the "slam" worked! pretty happy right now!
    38,305
    Re: Water Balancing
    Congrats!
    Now make sure you never let the FC drop below the minimum for your CYA level and you should be clear for the rest of the summer.
