Results 1 to 8 of 8
Thread: Help! Red clay from flash flood
    Guest
    Across the street new construction silt fencing was not strong enough for the flash flood we encountered tonight. I now have a very cloudy pool from red clay. I lowered the pool water and now am running filter and polaris. SWG is on super chlorinate. Any other suggestions?? Will my filter be wrecked???
    38,404
    Re: Help! Red clay from flash flood
    Welcome to TFP!!!
    I would recommend saving the life of the SWG and switch to liquid chlorine. What kind of filter do you have? It will not be wrecked as long as you clean it whenever the pressure rises 20-25% over the normal clean pressure.
    Check out the same discussion in this thread:
    flood-water-in-pool-need-help-please-t65645.html
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP.
    That's a bummer. I would keep an eye on filter pressure and backwash as needed.
    Good luck.
    Jeff
    Guest
    Thanks everyone for the quick replies. I have a Hayward Pro Series Sand filter. Pool is 21,000 gal. and was perfectly balanced before all this South Carolina rain we have been getting. I will send hubby out to the store for bleach. Any idea how much to start with?? Our chlorine level was around 6 before all the rain this week.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Chlorine level will depend on your CYA level. Can you test for CYA and post result ? 6 is for a cya level of 30 ppm.
    Jeff
    Guest
    Unfortunately I can't. Stupidly been relying on pool store numbers. Before this, CYA was at 60.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    I would suggest a skimmer sock or some panty hose to catch some of that extra red clay too.
    Jun 2012
    Howell, NJ
    977
    It would be much easier to clear your pool if you invest in the proper test kit, which can be found in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
