Thread: Need help with levels
    I have a 16' x 4' AGP. I have been using the 3 in 1 tabs from walmart for sanitizer and the shock they sell. I also have added their sanitizer and algicide and have used 3 jugs of the pH down trying to lower TA(using areation between doses of pH down) I went to the pool store and told them I added the shock first per the instructions before sanitizer and he asked me what I was shocking if there was no sanitizer. Are there any stickies explaining to me what shocking is?
    Currently my levels are:
    Testing with the HTH 6 way strips:
    TH - 400
    FC - 0
    pH - 7.8
    TA - off color
    CYA - 30-50
    Testing with the HTH 6 way drops:
    TC - 0.5
    pH - 7.5
    TA - 280
    TH - 540
    CYA - I do not understand the disappering dot. It never dissapears.
    The water is cloudy with no color. No burning in the eyes and yesterday, the FC was 10. Not sure what to do to keep chlorine in. Like I said, I am using the 3 in 1 tabs by HTH for sanitizer but would like to switch to using BBB. Can I just switch to that method?
    Intex vinyl 18' x 48 " AGP
    Learning the ropes so I can grow up and have my very own big kid pool! (IE -SUPER NOOB!)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, you can just switch to that method. You don't need to use their "shock" or "algeacide"
    Just use bleach. Read the "stickies" which will give you a link to the pool calculator to figure out your shock level. You have no CYA which is why the black dot is not disappearing. That is also called "stabilizer" which you can buy at Walmart. You ideally want that to be in the 30-50 ppm range, which will help your chlorine sanitize better. To lower your PH and TA, use Muratic Acid, which you can buy at Lowes or Home Depot, it comes in jugs. Ask a salesperson.
    Welcome to TFP. YOu have found the right place, you'll have an inexpensive and sparkling clear pool in no time!
    11,969
    Here's a link to a "sticky"
    http://www.troublefreepool.com/viewtopic.php?t=2375
    It tells you a good amount of info that you should learn, and gives you the links to the pool calc and other useful info.
    11,969
    I forgot to add,
    The test strips are not very accurate. They said my CYA was normal, in the 30-50 range, when it was actually over 120 and it was a big source of my former pool troubles...
    Stick to the drop test and perhaps upgrade it?
