Thread: Help with new pool package
    I am in the process of selecting a pool and equipment package for my family. I think I have decided on the 20' Matrix. I want to run a saltwater system. I am having dificulty seteling on a filtration system. I know everyone has thier favorite. I was leaning toward a sand filter. Should I do a Sta-rite 1 HP 19" filter or a Sta-rite 1.5 HP 22" filter? The specs on the smaller system says up to 19K gallons and I will have just over 10K gallons. Seems like it would be plenty, but there is only $35 diferance in price.
    Also looking for recomendations for saltwater clorinators. Intex is cheap. Maybe too cheap? Was thinking Hayward AquaTrol. Don't want an in-pool like the Saltron because I know my kids will mess with it.
    Would like to install 24" in ground, but was not recomended with the Matrix. Pools that are rated for semi-in-ground seem much higher priced. (Prob just do standard install)
    Any other info is great. Total rookie trying to learn al this!
    20 x 52 Intex Ultra Frame AG, 8K gal, 1600 GPH Intex sand filter, Intex SWG (copper unplugged), setup 7//14/13 Pearland,TX
    kellyetheredge's Avatar
    Mar 2013
    Lubbock, texas
    43
    Re: Help with new pool package
    We just put up our INTEX 32x16 AGP. We went with the INTEX 2500 filter/SWG set up and it rocks. Does a great job circulating and chlorinating the 14,000 plus gallons of water.
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH**Nite-Brite Halogen Pool Light
    TF-100 Test Kit (This kit Rocks)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, smithder
    For a sand filter and your ~9400 gallon pool we would recommend a minimum 1.8 sq. ft. sand filter (or 18" diameter) but going bigger (to an extent) will be better.
    For the pump, if you are going single speed I would not go any higher than a 1 hp. However, we would recommend looking at a 2-speed option. Here is a nice combo that would be great for your pool: http://www.poolsupplyworld.com/Penta...060DO2260.htm?
    Personally, I have had good luck with my intex swg (it is on it's third year) in my 11000 gallon pool, but it is a no frills unit that once it dies is done.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    +1 for the 2 speed pump. I have a 1 hp 2 speed and love it.
    Jeff
    What does the two speed do for you?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    One thing it uses less electricity on low. It filters better on low because the water is going thru the filter slower. If I see the need for more skimming action I'll use high. For adding bleach I use high also to mix better.
    For general filtration I use low.
    Jeff
