Thread: How to fill in gunite around spa jets?
    I used the Waterway spa jets in my new pool build. As per the instruction you must cone the gunite back 4” behind the PVC pipe when finishing the wet gunite. I explained this to the guy during the shoot to which he replied "I know how to do these, this is the kind we always work with." Well...... obviously he did not, as the pipes were only coned back 2 1/2". The guy that has done much of the work on my pool had to take a hand saw, hammer and chisel etc and chip the gunite back 2 1/2' in order to get the niches in the right place for plaster (flush with the wall) The niches are in the right place now, however the hole around them is uneven and ugly from the chiseling back. He told me to mix up some Portland cement, sand, and water and fill in the uneven chisled area around the jets. Is this correct? Do I need to apply anything to the existing gunite first in order to get the Portland to adhere? Also do I fill in the Portland flush with the niche, or leave it coned back a bit. I can post some pics if it will help. He also had to chip back a few returns in the pool to get the wall fittings on. The guys that did my gunite did an extremely sloppy job and as any of you that have read my previous post already know. Also some of the PVC was not straightened during the shoot as well, so some of my fitting point a little downward or upward instead of straight out. Thanks again. I should sign....... always asking how to fix a screw up!
    PS Pool to be plastered this week
    Owner/Builder- Pool under construction- Started 4/18/08
    20X40 freeform 3 1/2" to 8 1/2' deep
    elevated 8' spa w/ spillover
    Plaster: Undecided
    Pentair intelliflo
    Pentair intellichlor
    Pentair Mastertemp 400,000 BTU gas heater
    Pentair Triton II 30" sand filter
    LED (probably colorlogic) 3 in main pool and 1 in spa
    Polaris 280 w/ booster pump
    Control System: Still working on this Intellitouch I guess but don't know all the components I need yet.
    New Jersey
    51
    I would insist on the contractor correcting these mistakes before the plaster is applied.
    Why are you accepting this improper work?
    owner build
    sorry I should have reminded the board that this is an owner build. Any mistakes are mine to fix! The decking was poured yesterday and the concrete crew mixed up some portland I had here and filled in the holes for me. It was an easy fix, I just hope that was alright.
    Plaster: Undecided
    Pentair intelliflo
    Rocklin, Ca
    467
    You may be an owner builder but you are paying each contractor to do their portion correctly. If they missed something, they should remedy the situation. You are merely acting as the project manager.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
