Thread: PoolSkim and skimming
    tcat's Avatar
    May 2012
    Austin, TX
    713
    I've read some good reviews on this product. A question somewhat related.... I have a dedicated pressure line/booster pump for my retired pressure side cleaner. I was thinking of piping that directly into other return line and using it as the supply for a PoolSkim. This is piped with much smaller pipe (1" I think), will this make the Poolskim work better because it will likely be higher velocity? The return is in a good spot for a secondary skimmer (opposite the main skimmer and downwind).
    Question #2. Can you buy 90 degree fittings that will connect to existing returns (instead of ball joints)? I can only direct the return water at about 45 degrees. I think if all could be set at 90 degrees, the water would rotate all the crud to the skimmer much faster.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: PoolSkim and skimming
    I love my PoolSkim (and need to finish up my thread) but one issue I see is that the PoolSkim is made in South Africa with 50 MM metric fittings. You may have to make some custom fittings to adapt. The PS attaches to the return fitting using an adapter fitting that threads onto the return fitting.
    The adapter to the PS is a US return fitting faceplate (1.75 inch) glued to a male 50MM union tail piece.
    As for velocity, my pump puts so much water into the PS that it spun on the fitting and I needed to tighten the fitting. The suction created by the PS can be huge. I am looking to add a fitting to control/manage the flow into the PS.
    -- Guy --
