Thread: other use for acid/base demand reagents of K-2006?
    Diver's Avatar
    May 2011
    South of Boston
    450
    is there any possible use for acid/base demand reagents except their primary purpose? pool calculator renders these tests obsolete and reagents just end up sitting in the kit.
    one of them has sulfuric acid as does some other reagent (don't remember which one), so i'm wondering if they could be used for some other tests. i would guess not..
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: other use for acid/base demand reagents of K-2006?
    If the sulfuric is 0.12N you can use it for TA titrant.
    Essential Links:
    Diver's Avatar
    May 2011
    South of Boston
    450
    it says <1% on the reagent.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well, I'm not sure then. Sorry,
    Essential Links:
