Results 1 to 8 of 8
Thread: Should I put a sock on my Intex 1600 basket?
    Haley's Avatar
    Jun 2013
    Washington
    73
    Hi all,
    Doing some reading and wondered if I need to put a skimmer sock on my little basket in my Intex 1600?
    Oh, I guess I have another question... do I need to buy a wall skimmer? The pool doesn't have any trees around it and really the only thing I deal with are bugs. (Oy, one more potential thing to buy.)
    What'cha think?
    Intex 15'x48" AG metal frame pool (4,440 gal), Krystal Clear (1600) 14" sand filter, Taylor K2006 test kit, Intex Deluxe Maintenance Kit/vacuum (love it!), Intex Deluxe Skimmer, BBB.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,012
    Re: Should I put a sock on my Intex 1600 basket?
    If you can do it easily, sure. A knee-high nylon is cheap, and it will catch a whole lot of fine debris that would otherwise clog your filter.
    JamesT's Avatar
    Jun 2013
    Little Rock, Arkansas
    48
    I have bamboo growing just across the fence from my pool. When the wind blows a bunch of the little needles get in to the pool and if I don't catch all of them with the hand rake they get sucked into the skimmer and into the pump. This clogged up the impeller on my Intex 1600 and I had to take it apart and clean them out.
    I bought a package of skimmer basket socks (4 for $4.50) from Family Leisure Pool Store and they fit great. No more little needle problems. Catches a lot of bugs to. I just wash it out every morning and have been using the same one for a week or so now.
    8 year old Intex 16 x 48 metal frame - Intex 1600 Pump with 14" sand filter - Intex Old Style SWG (ladder broke and poked huge hole in the side)
    New 18 x 48 Ultra frame Intex - Intex 2650 pump with sand filter - Intex Old Style SWG
    Haley's Avatar
    Jun 2013
    Washington
    73
    That's great! Thanks, Richard and JamesT! That's what I'll do, then!
    JamesT's Avatar
    Jun 2013
    48
    Oooooops...I spoke and then went back and looked at your post again. You were talking about the pump basket and not the skimmer basket. I was talking about the skimmer basket. I don't think the socks that I was talking about are going to work on the pump plus I wouldn't want to have to take the top off the pump basket and clean that out every day......Sorry, my bad!
    Haley's Avatar
    Jun 2013
    Washington
    73
    Okay, interesting. So is it not good to open up the clear plastic lid that leads to the basket too often? It's super easy to get to and open up- or does it mess with the pressure inside the pump?
    JamesT's Avatar
    Jun 2013
    48
    Well actually I wasn't talking in terms of it not being a good thing or causing any problems, just that i dont like to unscrew it and mess with it. I would rather just dump the skimmer basket
    Haley's Avatar
    Jun 2013
    Washington
    73
    Gotcha! I think I'll try it in a couple of days (unless someone chimes in and says it's not a good idea or something). Thanks for your input, JamesT!
