Thread: Jandy ST-T Body Leak
    Jun 2013
    GTA, Toronto, Ontario
    119
    Hello,
    I believe i have a crack underneath my Jandy ST-T filter. The reason i suspect a leak is that there is always water behind the filter on my pad. I do not see any other sources where the water could be coming from.
    Is it possible to fix a crack?
    I know water is leaking from "somewhere" but itcurrently it does not appear to be impacting the pool water level at a noticable level. Can i just leave it for now or because the filter is pressurized, would there be concern of it suddenly getting worse?
    77000L (20500 gallon) vinyl in-ground chlorine double roman pool, 35'x17', Hayward SP3200VSP, Jandy Lite2 LJ400N heater, Hayward S244TC filter, *deleted* Hayward chlorinator, Taylor CK1004FAS+CYA
    22,548
    Re: Jandy ST-T Body Leak
    If the filter body is cracked it should be replaced. I never recommend repairing a pressure vessel.
    I would spend some time trying to locate the leak just because it would bug me not knowing.
    Jun 2013
    119
    I'll see what I can do. The darn thing is pretty heavy and I don't see any easy ways to remove the sand.
