Thread: Sodium Bisulfate Questions
    Jul 2012
    Chicago, IL
    356
    2 questions:
    I found some sodium bisulfate (with a fancy label/name) left by previous owners in the pool shed, does it have a shelf life in terms of effectiveness? I'm in Chicago so this stuff would have experienced triple digit heat as well as below zero temps over a few years.
    From a search of the board, it seems this is also known as "dry acid" for purposes of using the pool calculator, is that correct?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Sodium Bisulfate Questions
    Yes, "dry acid" is sodium bisulfate. Acids usually retain their strength well so it's probably still in good shape.
    Jul 2012
    Chicago, IL
    356
    Thank you!
