Results 1 to 7 of 7
Thread: Pool pilot dig-220 power module capacitor cans bulging
    Jun 2013
    charleston sc
    4
    The ends of the Caps are bulging. The three grouped together on the top left of the board.
    Should this be a concern? Normally in electronics this can mean the Cap is bad.
    Cap=capacitor
    Thanks
    George in SC
    22,550
    Re: Pool pilot dig-220 power module capacitor cans bulging
    Is the unit still operating?
    I'm like you, bulging caps mean they're bad or going bad.
    I seem to remember a thread or so about those caps. You migh try searching for it if you're interested.
    Jun 2013
    charleston sc
    4
    The unit is not working, that was how I found out about the caps(when I opened the box)
    Pool pilot seems to think the display board is the problem but I need to call them back and be
    at the unit with a meter for them to determine the exact part that is bad.
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    Any bulging capacitor should be replaced asap. With bulging caps, at least a couple of things can happen...both of them bad. First of all, the capacitor can short out internally and destroy other components which may or may not be much more expensive than a replacement cap. Finally, the cap can continue to bulge and finally explode, spilling its "internals" all over the inside of the unit. Bulging, as in capacitor or stomach, is a predictor of things to come and should not be ignored!
    Bosqueboy in Virginia
    In-ground 20,000 gal vinyl Grecian, Hayward Star-Clear Plus C1200 cartridge filter, Hayward 3/4 HP Superpump, AquaRite salt water chlorine generator, Heat Siphon C575HP heat pump and Blue Diamond robotic cleaner.
    Jun 2013
    charleston sc
    4
    I will need to get the info on the caps so I can order. Any suggestions where I may find this info?
    The problem with the pool pilot was a bad doublre pole switch that supplies 220 power to the controller.
    I replace the switch and the controller came right up.
    22,550
    The values should be listed on the side of the can. Also pay attention to the polarity stripe.
    Jun 2013
    charleston sc
    4
    Thanks for the help.
