Results 1 to 11 of 11
Thread: SWCG Raising FC too high
    Feb 2012
    Maryland
    400
    Help with FC rising
    I started my system off with bleach, I raised FC to 12 as I was heading out of town. Once FC was down to 4, I started the SWCG. I initially set it to 80%, after a day my FC was at 7. I lowered it to 70%, the next day FC was 8.5. I now set it to 50% and the next day (today) it is a 9.5.
    My pump is currently running on high speed 24 hours per day.
    Should I lower the salt cell percentage more, or have the pump cycle off overnight, or have the pump run on low most of the time?
    FC = 9.5
    CC = .5
    PH = 7.5
    TA = 320
    CYA = 55
    Salt = 2930
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    May 2013
    North East Ohio
    959
    Re: Help with FC rising
    Well I can start by saying high speed 24 hours a day is major overkill...mine runs on low a total of 6 hours a day.
    Other experts with SWCG will surely chime in and help out.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Feb 2012
    Maryland
    400
    Quote Originally Posted by toofast
    I want to make adjustments slowly, so I went ahead and turned the filter on low. Ill run on low 24 hours. I also lowered cell percentage to 45%.
    I know the cell percentage will affect FC, wasnt sure though if the pump run time or speed would.
    Feb 2012
    Maryland
    400
    I posted this in the BBB forum, but realized it was more SWCG so am moving it here.
    Topics merged. Please keep everything relating to one project or question together in one place. That is far more important than getting it into the correct forum.
    My FC is climbing each day and I am not completely sure why. I initially set it to 80%, after a day my FC was at 7. I lowered it to 70%, the next day FC was 8.5. I now set it to 50% and the next day it is a 9.5. Now im at 45% and my pump is on low speed for 12 hours (was previously high for 24) and this morning FC was 11
    Seems no matter what changes I make, FC just climbs.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,605
    Re: SWCG Raising FC too high
    Maybe you should consider lowering your run time? What gallons is your SWG rated for vs. your # of pool gallons?
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    If your CYA is too high it will keep FC longer/better than normal.
    Also how is your SWCG sized to your pool?
    I bought mine oversized on purpose and run it at 10-20% most of the year.
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Feb 2012
    Maryland
    400
    Well, I didnt realize it at the time, but mine is supposedly undersized. I have the T-CELL9 and my pool, according to my dig specs, is 22k. Glock30, I see you have the same size as me (18x36) and yours is 26k, how did you get that number?
    CYA is 50.
    I will lower runtime back to 8 hours today and see if any change. Note though that run time WAS 24 hours on high speed and has been 12 hours on low speed for the last day and FC is still climbing
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    I used the gallon calculator in this:
    http://www.poolcalculator.com/
    18 x 36 x5.5 deep
    38,292
    Pump speed will not affect the SWG output. The % setting is the amount if time the SWG is generating while the pump is on.
    So 50% for 24 hours either make the same chlorine as 100% for 12 hours ... but in the second case you would save 50% of your pump electricity.
    Generally you set the pump run time to keep the pool clean and then set the % to give adequate FC.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I can attest that it can be difficult to "dial in" your SWG. My personal issue is that my pool is constantly covered and i loose/use very little chlorine, so once it's in, it's in. I have considered buying a chemical you can add in the pool to remove chlorine when mine climbs, but i've yet to do that.
    Unfortunately you are just going to have to experiement to see how little you can run your pump and still keep your pool clean to your liking while producing enough chlorine.
    24 hour pump run time most likely is unneccesary and is costing you money.
    Edit: Remove inaccurate statements about target pool water turnover rate.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    38,292
    There is really no point in moving all the water 1 time in a day. See the article in Pool School about pump run time.
