Results 1 to 7 of 7
Thread: Pool popped now rebuilding
    Jun 2013
    New Jersey
    48
    I am new to pools but am a handy guy. I would love to save some $$ and repair my pool myself, I just want to make sure I do it right.
    When we bought our house and opened the pool, there was a small void in the bottom of the liner. It popped and the pool lost all of its water. Where the pool water rushed out is now about a 3' x 5' pit. It is just beneath one of the pool supports.
    My questions are these:
    1. How should I fill the hole to make sure the void doesn't happen again?
    2. Can the pool support just rest on the ground/sand, with the concrete footer that is already there?
    3. Does it matter what kind of liner I get?
    4. Should I just hire someone I trust, because I know a pool guy I can trust. I am just trying to save some cash.
    5. If I need sand, where is the cheapest place to buy it?
    Thanks all for the help. My main goal is to do it right at the cheapest price. I don't want to end up here again in a few years.
    21' round AG, 10k gallons, Proline Pump - 2HP - 2Speed, Sand filter - Brand and size forthcoming
    Water features - my 4yr old splashing me
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    Re: Pool popped now rebuilding
    Do you have any pics of what you are talking about? The cheapest and easiest way to fill the hole would probably be with dirt. After every inch or two added, it will need to be tamped to pack it tight, so that it doesnt settle alot. And I wouldnt get in any hurry after filling it because dirt always settles to some extent. Yes it does matter what kind of liner you get. What type do you have now : overlap, beaded, etc. The thicker the liner the better they are. Liner are fairly easy to replace. There is a good you tube vid called SUPER SIMPLE above ground liner replacement to give you an idea if this is something you could do yourself. When I get a big project going I usually get a few friends over and pay them in beer.
    20,000 gal. 27' AGP
    Hayward 18" sand filter with 1 hp Hayward Matrix pump
    A convinced BBB user and TFP fan
    Jun 2013
    New Jersey
    48
    Not sure what type of liner. I will look at it when I get home. I posted pics on another string found here:
    http://www.troublefreepool.com/pool-popped-t65207.html
    Not sure if I need to take that part of the pool apart to tamp it down or not. Not really sure where to begin with this and am tempted to just pay someone. We'll see.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I am not a expert here but if you filled the hole with a compactable gravel (Modified 2A is one IIRC) and compacted it every 6 inches or so, you may be able to fill the hole. If you figured out the dimension you could ask the yard what it would take to fill that hole with compacted gravel. I think its about $30 a yard around here.
    -- Guy --
    Jun 2013
    New Jersey
    48
    Yeah, I was thinking gravel mixed with sand to fill the gaps. Would you suggest sand at a yard or a pool place?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    No sand! Call yuor landscape or gravel supplier and tell you need a compactable gravel. They will know what they have. I am not sure a road base is correct. let them know it is under a pool and it need to be compacted. The 2a or equivalent is the one I hear talk about here. My local yard seems to have what they call "3/4 AB#2 Road Base". Call the gravel guys and ask them what they recommend. Order a little extra and you can use any extra to make a pad for your pump or a ladder landing pad that doesn't get muddy like mine.
    -- Guy --
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    A small layer of sand goes over the dirt or the rock. You do not want to use any sand for the fill at all. I would be concerned rock working its way up through the sand over time if it was used. My neighbor has an area of gravel under his liner and nobody knows how it got there.
    20,000 gal. 27' AGP
