Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 45
Thread: Pentair vs Hayward filters
  1. Back To Top    #21
    Jul 2013
    NJ Northern Bergen County
    26
    Re: Pentair vs Hayward filters
    OK here we go:
    FAC .5 now 5
    TAC .5 now 5
    PH 7.8 now 7.4
    TA 110 now 80
    CYA 40 now 20
    Calcium Hardness 210 now 290
    Salt 2800 now 2800
    Phosphates 300 now 0
    Doug - Northern Bergen County New Jersey
    21' x 40' in ground pool, 35,000 gallons, (8' to 3' deep), vinyl liner, Aquabot T4
    2 returns, 2 skimmers, 1 bottom drain, 2" piping around equipment - reduces to 1 1/2" to pool
    Pump ( need new one - using a borrowed 2 hp now), Filter - Pentair Quad 80
    SWG Autopilot CR 52, Heater - Raypack Model R 406A BTU 399,000 gas
  2. Back To Top    #22
    37,399
    Where did those results come from?
    Order the kit NOW so it will bo to you early next week
    Likely the FC > 5ppm if those are pool store results ... and how did the phosphates miraculously disappear?
    In a pinch you can dilute the pool water with distilled water and use the pink DPD kit with multiplication factors:
    50 pool / 50 distilled ... Factor x2
    33/66 ... x3
    25/75 ... x4
  3. Back To Top    #23
    Jul 2013
    26
    Both tests done at Leslie's by different people. Agree with phosphates. Trying to find some CYA in the area. Otherwise what else? I think I might wait until the AM and see what's up. Thoughts??? Alkalinity dropped. i agree with you about my FC is higher than their reading. Thoughts on what, if anything, I should do before it runs over night?
  4. Back To Top    #24
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Those results are great examples of why you need to get an appropriate test kit like jbliz said. It is hard for us to give you advice, since those numbers are not very reliable. Bottom line you need to be doing the SLAM process, but that will be difficult without an appropriate test kit: http://www.troublefreepool.com/pool-...king_your_pool
  5. Back To Top    #25
    Jul 2013
    26
    Good morning. I just looked outside from my upstairs window and I can see the Aquabot pretty good sitting at bottom of the pool. I know my original post of "my pool is green" is subjective, but i'm very happy with the rsults of 24 hours! Looks like I am on my way to getting the water good enough for party tomorrow afternoon. Test kit is on its way, but won't be here until next week. Will test water again at pool store this AM. I'm sure filter needs to be cleaned too. I slammed four times yesterday, once before bedtime. Ran pump over night. Added baking soda and stabilizer ( I couldn't find 20 Mule). You guys really kept me on track! Where do I send the case of beer!!!
  6. Back To Top    #26
    30,133
    Nope. If you do it by following the instructions carefully, you will ONLY SLAM the pool once.....it's a process, not a dose of chlorine.
  7. Back To Top    #27
    Jul 2013
    26
    My terminology was incorrect. I "slammed" the pool once. I am getting great results. Thanks
  8. Back To Top    #28
    30,133
  9. Back To Top    #29
    Jul 2013
    26
    this morning's test:
    FAC 1
    TAC 1
    PH 7.0
    TA 90
    CYA 30
    Calcium hardness 280
    Salt 2750
    Looks like I still had algae or something in the water overnight. Makes sense to me as I slammed it yesterday.
    Cleaned filter this AM too. Third time I cleaned filter totally since yesterday AM (pulled out cartridges and hosed off). All good so far. Increasing pH and adding liquid chlorine and CYA in a few hours. Thoughts?
  10. Back To Top    #30
    Whatever you are calling "shock" is probably not the correct procedure for dealing with this situation. [slam:1num2m91]You need to SLAM the pool.[/slam:1num2m91]
  11. Back To Top    #31
    Jun 2013
    SpringHill FL
    415
    Slam= shock level and maintain so if you are at a fc of 1 your not slaming your pool!!!
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
  12. Back To Top    #32
    Jul 2013
    26
    I had it above a FC of 5 all day yesterday, failed the overnight test, so I'm raising the FC again today for another overnight test.
  13. Back To Top    #33
    Jun 2013
    SpringHill FL
    415
    Normal recomended cl levels for cya of 30 are 3-7 so to slam it you would want to be higher than normal level (we may have a communication barrier of some sort) but the slaming procces requires you to maintain Shock levels of cl until 3 things happen reread slaming procces please
    Nathan
  14. Back To Top    #34
    Jul 2013
    26
    You said it, as I was thinking it. Communication is an interesting thing. Doing the best I can without the kit. It's on order. Regardless, Friday morning my pool was green and I could barely see the bottom of the shallow end 3'. New filter and following your slam process as best I can. I'm on the upward slope of the learning curve here. My pool is now clear, very clear!! Extremely happy. I do understand that I am still in need of the kit and need to complete the slam process until my TAC doesn't drop more than 1 overnight. Thanks! Picking up my beer now.
  15. Back To Top    #35
    Jul 2013
    26
    Cleaned filter for the fourth time after psi increased by 10. I'm kicking the green stuff's butt! Clear water!
  16. Back To Top    #36
    Jul 2013
    26
    Good morning. I have the K-2006 and am testing water for the first time. The chlorine test says if free chlorine is present, sample will turn pink. I must not have any free chlorine present because no change in color to water in test tube when I added the R0870. So how do I know how much chlorine to add?
  17. Back To Top    #37
    30,133
    The amount of FC you need is dependent upon your CYA level.
    Test for CYA, go to the FC/CYA chart in pool school and it will suggest where your FC should be.
    Then, go to poolcalculator.com to calc your dosage.
  18. Back To Top    #38
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Post all of you results here and we can help you to learn the process.
    -- Guy --
  19. Back To Top    #39
    Jul 2013
    26
    I'm not getting any reading when I test the FC. Can it be that low???? Water is clear
  20. Back To Top    #40
    Jun 2013
    SpringHill FL
    415
    It could be low yes, test everything and post your results plz
    Nathan
