Thread: newly plumbed intex ultra frame 18 x 9
    May 2013
    Chandler Arizona
    78
    I just plumed this. The only thing I did not do is change out the Intex plungers. to PVC. Does anyone think this is a needed ( the PVC instead of Intex plunger) I want to add water feature this week to cool water. can I run feature and inlet at same time. running 1250 sand filter and swg both intex.
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    May 2013
    Chandler Arizona
    78
    Re: newly plumbed intex ultra frame 18 x 9
    More pics of plumb
    May 2013
    Chandler Arizona
    78
    more pics
    May 2013
    Chandler Arizona
    78
    Would you guys hard plumb sand filter to the SWG too?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Commenting for reference...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
