Results 1 to 11 of 11
Thread: My hair has turned green!
    Jul 2013
    British Columbia/Canada
    10
    New to SWG this year. I'm following the information I have found on this site and my pool is mostly good. There is so much information on this site that I cannot find what I'm looking for. I seem to have a small problem with what I think is pollen collecting on the bottom of the pool. I keep cleaning and changing my filters and vacuuming and I am slowly getting ahead. My main question or problem is the bottom 6 inches of my hair have turned green! I have come across some information saying I should unplug the copper plates. Is this really the right thing to do?
    16 x 48 intex pool
    Krystal Clear Filter Pump
    Krystal Clear Saltwater Sysyem
    Galaxy 21' x 54" 11 700 gallon A/G pool, Hayward Turbo Flo ll pump 1.5hp, Hayward 19" Sand Master filter 40gpm Vari-Flo XL valve, Krystal Clear SWG, Hayward pool heater 100 000 btu, Taylor K-2006 test kit., Wally the Whale auto pool cleaner. Installed July 2014.
    38,251
    Re: My hair has turned green!
    Welcome to TFP!!!
    Well, unplugging the bars is a start. Copper is what turns your hair green. Your SWG is adding copper. Copper can also be added in some algaecides (almost never recommended) and in some multi-purpose trichlor tablets.
    The problem is at this point the copper is already in the water. To remove it, you would have to replace the water.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, MrsD
    As jbliz said, unplug the copper bars. No need for your hair to turn green.
    Jul 2013
    10
    Holy...that was a fast reply, Thanks. I didn't add anything with copper so it's the SWG. Why do they have copper bars?
    I will disconnect copper bars and start draining some water, Thanks again.
    This site is awsome!
    Jun 2012
    Butler, PA
    336
    Go to a beauty supply house and they will have a shampoo and conditioner that will bring your hair back~ both its color and texture. My daughter went Kermit last year ~ copper via Pristine Blue. The shampoo & conditioner brought her right around. Just started using it again this season, every couple shampoos as she swims all the time and is out in the sun all day, it conditions nicely. Wasn't at all pricey & I am sure local salons carry the same stuff, beauty supply house just sells more of it for a cheaper price and when we started last year I though for sure I needed it in 55 gallon drums.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Sep 2009
    Greentown, IN
    914
    They have the copper bars to help keep algae away. Copper is a natural algaecide that is often found in products to keep algae away. When it comes in contact with chlorine it oxidizes and causes the green color.... that lighter colors of hair will then pick up.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Believe it or not, ketchup will remove the green tint from your hair. Use it just like shampoo and leave it in for about 10 minutes before you rinse it out. I saw my hairdresser use this trick on a lady's hair last summer.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by MrsD
    It may have a lot to do with the misunderstood chlorine/cya relationship by industry. Intex calls out in their manual cya levels: 10 ppm minimum, 30-50 ppm ideal, 100 ppm maximum. If you maintained your cya at 30-50 and if you pool is larger and get's a lot of sun, the intex swg will never keep up, so some supplemental protection comes in, cue the copper as an algaecide. Additionally, in ~2010, intex reduced the output of their cell by 1/2 at the same time they added the copper bars, exasperating the low cya causing low chlorine in the pool so the copper might also be there to help offset this a little in larger pools (they now make some much bigger pools then they used too). However, the intex is quite able to keep up with with decent volume pools (mine is about 11000 with copper bars disconnected) and the highest run time I have needed is 8 hours, but of course I keep my cya level somewhere in the 65-80 ppm range.
    Jul 2013
    10
    Thank you for all the reply's. I am going to try ketchup in my hair, I read that a few other places also. If that doesn't work I will try something from a salon. I tried washing my hair with baking soda and rinsed with apple cider vinegar and that helped a bit, but not enough. Thanks for the copper bars 101 from "linen". Wish I had known about this sooner.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you haven't already take a look at this pool school article: http://www.troublefreepool.com/pool-...ater_generator
    Butterfly's Avatar
    South Carolina
    10,045
    Why use ketchup when you can use something that will remove the green and protect the hair, etc. Nexxus Aloe Rid, Walmart has it.
    You're done SLAMing when:
