Thread: What to do next?
    Jun 2013
    Troy, MI
    9
    What to do next?
    Here are my latest test results after draining and refilling my pool by 50% twice.
    FC 1.5
    CC 0.5
    TC 2.0
    pH 7.2
    TA 70
    CH 130
    CYA 80
    Temp 84
    I'm guessing I should drain and refill about half the pool again to get the CYA down to normal range, but I figured I should ask.
    Should I add bleach to get the FC up before I do that or is it a waste if I am just draining water?
    Thanks for any help in advance.
    16 x 32 Rectangular IG Vinyl Pool 19,065 Gal 512 Sq. Ft. Surface Area Raypak RP2100 Heater Hayward SP-1084 Auto-Skim Hayward CL-200 Chlorine Feeder Hayward S-200 Sand Filter Hayward SP-710X32 Vari-Flo Filter Control Valve.
    Aug 2010
    Dallas, TX
    4,052
    Re: What to do next?
    You are correct, you have another drain to go. Don't add bleach if you are draining. Add it right when you start filling again.
    Jun 2013
    Troy, MI
    9
    Thanks. I am draining now. When I get the CYA down to the correct level, what should I correct for next? FC, pH, or TA?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would add a gallon of bleach when you start filling.
    just like Robbie said.
    -- Guy --
