Thread: Using Ozone to reduce chlorine
    Split by moderator from HERE. Please start your own thread for you questions. Thanks, jblizzle.
    I am learning about ozone to assist in reduction of chlorine because:
    * The burning it causes, when using a mask the build up after a couple of hours is not acceptable
    * Dry smelly skin
    * Dry coarse hair
    Have to raise a hand to Waterbear's scaring post.
    Quote Originally Posted by waterbear
    ... according to OSHA, 10 parts per million is considered Immediately Dangerous to Life, requiring urgent evacuation ....
    Your quoting ppm figures that is related to ozone in the air. Ozone dissolved in the water is entirely different.
    11-12k gal, IG plaster, Pentair Tagelus filter model TA-60/60D, Pentair Challenger Single-Speed High Flow Pool Pump 0.75 HP
    1 skimmer, 2 drains, 3 returns and dedicated suction w/Kreepy Krauly
    Located in NW Arkansas, Pool completed March/April 2013
    Installed with Pool Frog, planning to switch to BBB next year
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: salt water vs. ozone purification
    Welcome to tfp, Tfar Craw
    Ozone is not needed in a typical outdoor residential pool. Now to your reasons you stated:
    Quote Originally Posted by Tfar Craw
    I am sorry, but I do not understand this...do you mean burning inside a swim mask?
    * Dry smelly skin
    * Dry coarse hair
    Properly maintained chlorine levels will not cause this. Much of the problem is people take from their experiences in public pools (or improperly maintained private pools) and assume that this applies to all pools that use chlorine as a sanitizer. In fact maintaining the proper FC level for the pools cya level will eliminate these problems. See: http://www.troublefreepool.com/pool-...ya_chart_shock
    If you are assuming ozone will allow you to not use chlorine, then your assumption is dangerous since there is little residual effect of ozone in the water.
    Aug 2010
    Dallas, TX
    4,052
    Re: Using Ozone to reduce chlorine
    Poor pH balance will cause stinging eyes and hair issues also.
    You might be a candidate for a SWG. Salt pools are still chlorine pools, but can be maintained with higher CYA and lower FC levels, but are still safe and sanitary.
    But if you don't keep pH in balance, you'll still have stinging eyes and such.
    While ozone is different in the water, it doesn't tend to stay in the water. If ozone is allowed into the bulk pool water it will end up in the air and soon cause respiratory issues. Pools that use ozone normally do so in a separate mixing/reaction chamber, where the chamber is specially designed to insure that the ozone has broken down before the water exits the chamber.
    Mar 2007
    San Rafael, CA USA
    12,082
    Also keep in mind that the way we manage chlorine we are already reducing it considerably through judicious use of Cyanuric Acid (CYA). The minimum FC/CYA ratio that we recommend has an active chlorine level equivalent to only 0.07 ppm FC with no CYA. Compare that against public pools with even only 1-2 ppm FC but with no CYA -- 14 to 28 times as much active chlorine.
