Results 1 to 9 of 9
Thread: Pool Tile Repair and Replacement on a 55 year old pool
    May 2013
    Woodland, CA
    22
    We are renovating my Grandfather's 1958 20' x 45' swimming pool. We got everything working. After a year losing the great algae war of 2012, we have been victorious in 2013 and the pool has been crystal clear after following the procedures outlined on this site. Thanks to all...
    So, the last major issue is the tile. It has been cracking for some tiem and needs to be replaced. First of all, I think it cracking because the concrete deck is attached to the pool walls via rebar (I strongly suspect). So when some of the concrete deck slabs sink it causes cracking in the top of the pool where the tile is... My plan was to run a concrete saw where the deck meets the pool to eliminate this pressure. I may have to address soem issues with the sinking deck slabs... But that is another matter. I think this will eliminate the pool damage, which is more important. Thoughts?
    So once this is done should I... 1) Replace the tile with similar tile so the pool is as it was? or 2) update it with something better. Are there designs that would make more sense and improve maintenance, looks and or safety?
    Thanks for any replies! I know this will be a murderously tedious job...
    35,000 Gallon Painted Plaster rectangular pool built in 1958 by my grandfather.
    Pentair Intelliflo Variable Speed 3 HP Pump
    StaRite System 3 Model S8S70 300# Sand Filter
    Aug 2010
    Dallas, TX
    4,052
    Re: Pool Tile Repair and Replacement on a 55 year old pool
    Finally! Someone with a pool as old as mine!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I think separating the pool from the deck is a good idea...better late than never. Do you have any way of knowing how thick the pool wall is? you'd want to cut it on the outside of that line, then have your coping cover the entire top of the pool wall and butt up to the deck.
    Aug 2010
    Dallas, TX
    4,052
    My pool is separated from the deck somewhat. If you look at this picture, you can see where the deck and the pool coping have a gap. We've filled that gap with mastic since this picture. Pools (or decks, or both) aren't going to be in the same place they were when they were built!
    We also had the missing grout replaced... it looks GREAT now!
    May 2013
    Woodland, CA
    22
    It does look great! How old is the brick/tile work?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Will a concrete blade on a big saw cut rebar?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    Woodland, CA
    22
    Yes, it will dull the blade faster, but it will cut it.
    Jun 2013
    Las Vegas, NV
    8
    Quote Originally Posted by harleysilo
    Yes it will, with a diamond blade on a Target Quickie saw the only way you know you hit rebar is the sparks!
    Max
    11K, IG Plaster, Pentair CCP420 cartridge, 3hp Intelliflo VS, Approx 1974, re-plastered 12/2012
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    So if one was renting the saw, you might inquire as to charges for wear? Isn't it by the 16 th or 32nd of the blade? Can't remember it's been awhile since I rented one....
    18'x43' Sport Pool
