Thread: Question regarding tap water chlorine levels
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Ok. I went to my friend's house to check her pool water. She turned on the tap water and the chlorine smell was unreal. I checked the chlorine levels of her tap water and these were the results:
    FC-10
    CC-0
    I researched an acceptable level of chlorine for human water consumption and it maxed out at 4 ppm. When we called the water tech guy who maintains the levels, I was told by him, "The CC level is always high than the FC level."
    Am I confused?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Re: Question regarding tap water chlorine levels
    Many water companies use monochloramine, which is a combined chlorine, instead of chlorine, to sanitize drinking water. Monochloramine is fairly harmless, and not easily noticed as a smell. How that answers your question, or justifies an FC level of 10, is beyond me.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It does not explain it and I bet he got someone on that Chlorine injection rate asap. We have a high limit of 5.0 FC for drinking water in Texas. Minimum is 0.5 PPM. No matter what 10.0 PPM FC is way over any standard limit in the US.
    Essential Links:
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    I would check it again a few days later and see if its magically lower.
    I checked my tap water a few months back and we are at 2 ppm. Regulations here are maxed out at 4 ppm. Something seems fishy to me.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
