Results 1 to 10 of 10
Thread: how to REMOVE iron from pool
    OK I'm new to pool water maintainence and need some help from the experts. Here's the story: first year with a pool18x36 iunground. Filled it with my well water which has iron, pool went to tea brown within 10 minutes. Couldn't see anything. Had it tested came back positive for iron which I knew it would. Anyways I put some metal out sequestering stuff in the pool and two days later the pool was clear with a lot of precipitates on the bottom whish I vaccumed out. Swam in the pool this past weekend and had the water tested. This time the test said no iron and so i added two more bottles of shock and the pool turned brown again albeit a lighter shade of brown this time (can still see through the water whereas the first time you couldn't) so my question is how do I remove all the iron so I don't have to keep spending money on metal remover everytime I shock the pool?
    38,290
    Re: how to REMOVE iron from pool
    It is generally not possible to REMOVE the metal without pumping it out and replacing it with metal-free water. You must continue to add a sequestrant and replenish it at regular intervals.
    BTW, you should not be needing to "shock the pool" if you are maintaining adequate chlorine as we recommend.
    pool-school/metal%20stains
    30,421
    Short answer - you can't
    Since you have iron in the pool and your source of water is iron laden, that problem will plague you as long as you have your pool.
    Do you have a household water softener?
    I do have a household water softener in my basement that I fill up with the water softener pellets periodically
    30,421
    It (the water softener) will not have the capacity to fill your pool in one shot but it could provide your refill water and eventually your pool will be iron free.
    If you needed it to be iron free right now, you could drain the pool, truck in water, then refill with your softened water.
    OK thanks. I think truck water is too expensive
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    my water comes out orange.. eventually the water should clear up, you'll find the iron seems to settle like a powder on the bottom.. (at least thats what I think it is) the filter doesnt catch it, so I vacuum to waste after a good rain fall.. and loose a good bit of it.. I find after the first good fill the tea/coca color doesnt come back. once it clears up.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    Jun 2012
    Butler, PA
    336
    In our area we have pool water delivery services that fill pools, but several of our fire companies will for a fixed rate & some will "for donation" ~ the donation being what someone can afford. Prices are all over the board depending on who you call. My neighbor got her 24' AGP filled for $90.00 delivered. They brought it 20 minutes after she placed the call ~ we were floored at the price and how quickly they brought it. That's a heck of a deal and you will most likely have more than out in sequestering agent for the season.
    Not sure if you have possibly checked locally with your fire companies. That could possibly be an option for you.
    If you know someone in construction / landscaping ~ they could have access to water hauling trucks and nice water at a very economical price.
    Just putting that out there for consideration on the chance you haven't thought about those options.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Thanks. Will like into it
    Jun 2013
    Fallsburg, NY
    258
    Be aware that if you go with the local fire dept, you may get pond water unless you have a nearby hydrant. I looked into this when I filled mine (no nearby hydrants) and the trucks only carry 1000 gallons pumped from the nearest pond, and would have required 8 trips to fill mine. Then I would have been faced with an immediate shock process to clear the water. It only took 17 hours to fill mine with two garden hoses. Unfortunately even the municipal water is chock full of iron.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
